PCQ and hotspot, It is possible?
Hi guys, i have a client that have an hotspot radius system, radius is used only for ok or ko no queue limitations.
I know the speed incoming from wan (30-DWN / 3-UP) want to equalize entire subnet (10.5.50.0/24) like a normal lan with pcq.
I done this:
/queue simple
add max-limit=3M/30M name=EQ queue=pcq-upload-default/pcq-download-default target=10.5.50.0/24
In ip hotspot user profile:
/ip hotspot user profile
set [ find default=yes ] insert-queue-before=bottom parent-queue=EQ
Stop and reload hotspot service and seems to be working but i have some doubt…
In your opinion is the best way to do this?
How you add users underneath this queue and use pcq with radius?
Sent from my GM1913 using Tapatalk
