PCQ configuration in ver. 2.9
Can anyone help me on how to configure the following configruration done in ver. 2.8, to configure in ver. 2.9:
Bandwitdh limitaion for p2p trafic
add src-address=10.84.0.0/16 mark-flow=p2p-out p2p=all-p2p action=accept
add dst-address=10.84.0.0/16 mark-flow=p2p-in p2p=all-p2p action=accept
add name=p2p-out kind=pcq pcq-rate=56000 pcq-classifier=src-address
add name=p2p-in kind=pcq pcq-rate=56000 pcq-classifier=dst-address
add name=p2p-in parent=global-in flow=p2p-in queue=p2p-in
add name=p2p-out parent=global-out flow=p2p-out queue=p2p-out
Bandwitdh limitation for all user to get 128Kbps
add action=accept mark-flow=all
add name=PCQ-Down kind=pcq pcq-rate=131072 pcq-classifier=dst-address
add name=PCQ-Up kind=pcq pcq-rate=131072 pcq-classifier=src-address
add parent=global-in queue=PCQ-Down flow=all
add parent=global-out queue=PCQ-Up flow=all
The above mentioned configuration I want to implement in ver 2.9 but, what I can find in Mikrotik’s user manual is not very helpfull.
Thanks in advance.
Faton
Thanks in advance.
Faton
i guess where u are having problem is when marking the packets, and that is what makes the difference btw v2.8 and v2.9.
what u need to take into consideration is the command line ..e.g to mark packet with mark-flow=p2p-out :
add chain=forward src-address=10.84.0.0/16 action=mark-packet
new-packet-mark=“p2p-out” disabled=no
if you are succesful with your packet marking…every other thing is ok… PCQ in 2.9 still remains the same.
