PCQ in multiple LANs with SNAT - problem
Hello
I know that You wil answer could be RTFM … but beleave me .. I spend many hours on reading/googling before I created this topic.
My configuration is a bit different/complicated that regular ones that are commonly used.
I have 3 LAN (as subinterface/VLAN on one ethernet port) and one WAN port. Every LAN i SNATet to it’s public IP.
I’d like to proritize traffic from/to internet only. I’m not using bridge at all.
I’d like to configure PCQ to give my users (50 users) equall bandwith so according to
http://wiki.mikrotik.com/index.php?title=Manual:Queues_-_PCQ_Examples&redirect=no
it should be really simple …
But I have couple questions/daubts:
  • is it in my scenario I should mangle on FORWAD or PREROUTING?
  • I’m using 6.35 ROS and there isnt “global-in/global-out” but only “global” queue - is it the same?
  • if “global” replaced “global-in” how to get “global-out”?
  • I checked flow diagram but now I’m completelly lost - please point me in right direction
    Now I have code:
/ip firewall mangle
add chain=forward action=mark-connection new-connection-mark=LAN-down-con passthrough=yes src-address-list=Local_LANs comment="mark client traffic" disabled=no
add action=mark-packet chain=forward comment="" disabled=no new-packet-mark=all_packet passthrough=no
Local_LANs=192.168.0.0/16
Is this code will properly mark download traffic from internet?
With such mangle applied I see in “connection” tab connection that has “unknown 8” or “unknown 6” and of course a lot of “LAN-down-con”. What does it mean unknown 8 ir 6? why they appear?
I hope that someone could help me solve my problem.
With regards
SLawek
ROS 6.x packet flow: http://wiki.mikrotik.com/wiki/Manual:Packet_Flow_v6
Changes from ROS 5 to 6: http://forum.mikrotik.com/t/double-qos-for-v6-is-possible/60963/1
If all that you want is equal bandwidth sharing amongst all users, you don’t need mangle nor Queue Tree, can use simple queues with queue type pcq-download/pcq-upload (advanced tab) as stated at the end of the mikrotik wiki page you linked to in your post.
Hello
Yes - first step is to make equall bandwith for users. As stated in Wiki
/queue simple add target-addresses=192.168.0.0/24 queue=PCQ_upload/PCQ_download
Of course it doesn’t working because is outdated? It’s another time when I found errors on Wiki page.
Please help me to correst and I will ask support to corect this entry - It will help in the future peaoples to use Wiki documentation without frustration.
In my opinion this code should be:
 /queue simple add target=192.168.0.0/16 queue=pcq-upload-default/pcq-download-default
Please explain me why on Wiki is 192.168.0.0/24 not a 192.168.0.0/16? in my opinion should be 192.168.0.0/16 to cover every most common used 192.168 network adressess.
It seems to be working now, but I think that is is not enought. What about connection parameters?
Do I need to put it in General tab of “queue3” (why its name is queue3 not 2 as is in topic that You putet) MAX LIMIT for download and upload?
How to change this parameter using CLI?
Regards
Slawek
Seems that documentation is from a time where there weren’t predefined queue types, so you had to create them with the desired parameters, and name those queue-types as you wish.
ROS comes now with pre-defined queue-types, so its possible now to refer by them.
That’s just an example, you are the one in the better position to decide whose subnets should be the target of this simple queue.
That’s just a sequential name auto generated by winbox, you can rename it as you see fit.
Tips:
1.- Modify the simple queue (follow wiki page for target, max-limit and limit-at parameters reference) as your liking, then open a New terminal, and issue
/queue simple export
You’ll be able to see how values from Winbox translate to CLI syntax.
2.- While in a cli prompt menu, hit the tab key on your keyboard, it will show possible commands and parameters in a contextually-aware fashion; will also autocomplete them.
3.- See http://wiki.mikrotik.com/wiki/Manual:Console
Hello
So in my case, I have 192.168.11x.0/24 - should I put there every network address or use 192.168.0.0/16? Is that make change to ROS?
Do I need to put it in General tab of “queue3” MAX LIMIT for download and upload?
As you see fit, you should set it so it covers all the networks you want to apply that fair bandwidth share.
Yes, you have to, it is needed to know the total bandwidth available so that algorithms can operate effectively.
