PCQ instead simple queues, but... where ?
This is my installation:
MTK1 = Load balance PCC + QoS + User Manager
MTK2 = 2x PPPoE Server
MTK3 = 2x PPPoE Server
Now, i’m doing simple queues in every rb750.
I’ve different upload/download speeds: (64k/512k - 128k/512k - 128k/1024k, and so…)
PCQ… Where ?
1st - In MTK1 ? The radius info goes to MTK2/MTK3… so in MTK1 only have the src address :frowning:
2nd - One PCQ in MTK2 and other in MTK3 ?
Any ideas ?
Only can see one solution… fixed client ip in radius. :frowning:
Maybe using address-list in user manager…
Can i share “address-list” between routers ?
You can’t share address lists.
The best solution would probably be to run PCQ download (from Internet to user) on MTK1 - that way traffic gets thrown away on ingress and doesn’t take up bandwidth on the backbone when you’re just going to throw it away later. PCQ upload (from user to Internet) should be on MTK2 and MTK3 - again close to ingress.
The easiest scalable scheme is probably to assign either static IPs or DHCP/PPPoE address pools via RADIUS (the pool names, of course, scale a lot better - if User Manager can do that. Other RADIUS servers can). Then summarize the address space as appropriate and use it to identify service levels. For example, 64k/512k gets addresses from a pool that can be summarized as 10.1.0.0/24, 128k/1m gets addresses from a pool that can be summarized as 10.1.1.0/24, and so on. That way you can identify service level by source/destination IP throughout the entire network.
Alternatively you can also come up with a way to mark packets with DSCP when they enter the Internet or customers routers (which is carried in the IP header between routers). Then you can, on each router, mark the connection based on the DSCP value of a packet, and from there apply packet marks bidirectionally and make queuing decisions. That’s the big boy way of doing it, but it’s also a lot more involved and complicated.
Ok. I can set a pool name in usermanager.
For ex. user1=pool_1m, user2=pool_2m… and so.
And now, in every router, ip pools:
For 1024k up - 256k down
pool_1m:
 MTK2 - 10.11.0.0/24
 MTK3 - 10.11.1.0/24
For 2048k up - 512k down
pool_2m:
 MTK2 - 10.12.0.0/24
 MTK3 - 10.12.1.0/24
Correct ?
Now, in theory, i can track user from src-address.
Only a doubt…
Currently have:
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default \
    use-compression=default use-encryption=default use-vj-compression=default
add change-tcp-mss=default comment="" local-address=10.10.0.1 name=\
    profile_N00 only-one=default remote-address=pool_N00 use-compression=\
add change-tcp-mss=default comment="" local-address=10.10.1.1 name=\
    profile_N01 only-one=default remote-address=pool_N01 use-compression=\
add change-tcp-mss=default comment="" local-address=10.10.2.1 name=\
    profile_N02 only-one=default remote-address=pool_N02 use-compression=\
set default-encryption change-tcp-mss=yes comment="" name=default-encryption \
    only-one=default use-compression=default use-encryption=yes \
which ip have to put in “Local Address” in ppp profile ?
:-S
Thanks in advance, and sorry for my bad english!
PPPoE pools solved.
Thanks!!
