PCQ Not working
I’m trying to set up a PCQ for an event that i’m running soon but nothing that i have found seems to work. I followed this guide but i seem to be missing something
https://www.youtube.com/watch?v=7orlj8emv2k
Here is an export of my Current Configuration.
add admin-mac=E4:8D:8C:17:4F:AC auto-mac=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
    ether5-slave-local
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=\
    ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=\
    ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=\
    ether9-slave-local
set [ find default-name=ether10 ] master-port=ether6-master-local name=\
    ether10-slave-local
/ip neighbor discovery
set ether1-gateway discover=no
add name=dhcp ranges=10.37.0.100-10.37.0.250
add address-pool=dhcp disabled=no interface=bridge-local name=default
/queue type
add kind=pcq name=Download pcq-classifier=dst-address pcq-dst-address6-mask=64 \
    pcq-rate=2M pcq-src-address6-mask=64
add kind=pcq name=upload pcq-classifier=src-address pcq-dst-address6-mask=64 \
/queue simple
add name=LAN queue=upload/Download target=10.37.0.0/16
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=sfp1
add address=10.37.0.1/16 comment="default configuration" interface=\
    ether2-master-local network=10.37.0.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=no \
    interface=ether1-gateway
add address=10.37.0.0/16 comment="default configuration" gateway=10.37.0.1 \
    netmask=16
set allow-remote-requests=yes
/ip dns static
add address=10.37.0.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
    established,related
add action=drop chain=input comment="default configuration" in-interface=\
    ether1-gateway
add action=fasttrack-connection chain=forward comment="default configuration" \
add chain=forward comment="default configuration" connection-state=\
    established,related
add action=drop chain=forward comment="default configuration" connection-state=\
    invalid
add action=drop chain=forward comment="default configuration" \
    connection-nat-state=!dstnat connection-state=new in-interface=\
    ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ether1-gateway
/system clock
set time-zone-name=America/New_York
/system identity
set name=CGTik
/system routerboard settings
set cpu-frequency=650MHz
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=ether10-slave-local
add interface=sfp1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=sfp1
Try disabling fast path in IP->Settings.
This did the trick! thanks!
If you need to sharing equal bandwith should put the pcq equal 0 (pcq=0) and in queues limit at general upload and download like 1m/1m, in target put your network like x.x.x.x/24
And in advanced select pcq upolad and pcq download
Test your work.
In video and pcq=2m that meaning everyone have 2m from bandwidth.
Regards
