PCQ question
When I set up a PCQ for equal bandwitdh for a group of users, a full network address must be entered (10.10.10.0/24)
If I want to exclude certain addresses, lets say 10.10.10.1 - 10.10.10.10
Is this possible?
Thanks,
-dan
i had a situation like you… and I solved it doing this:
you have the 10.10.10.0/24 network in a PCQ_queue
you want to exclude some addresses… the point is what you want to do with those excluded addresses…
look this example
 0   name="PCQ_Excedidos" target-addresses=172.16.0.27/32,172.16.0.28/32
      dst-address=0.0.0.0/0 interface=all parent=none direction=both
      priority=8 queue=PCQ_up_excedidos/PCQ_down_excedidos limit-at=0/0
      max-limit=0/0 total-queue=default-small
  1   name="PCQ_normal" target-addresses=172.16.0.0/21 dst-address=0.0.0.0/0
      interface=all parent=none direction=both priority=8
      queue=PCQ_upload_normal/PCQ_download_normal limit-at=0/0 max-limit=0/0
in this example i give a different treatment to the hosts 172.16.0.27 and 172.16.0.28 … the rest of the 172.16.0.0/24 network fall in the second rule…
i don’t know if the sintax is right… and sorry for my poor english
Thats sort-of what I was thinking, but will this work:
create simple queue,
name=“exclude” target-address=10.10.10.2/32 max-limit=0/0
0/0 should not set a limit, if I place this before my PCQ 10.10.10.0/24 queue, will if override it?
Also, in my PCQ queue, since my router IP is included, 10.10.10.1 , I’m I correct to assume that this address is skipped? Or would it just limit traffic to the box itself? ( management )
Thanks,
-dan
This will work.
