PCQ queue - can't reach max bandwidth
Hi, I have become a member of Mikrotik supporters. Specifically, I purchased an rb750gr3 routerboard, which I use behind a DSL modem from a provider that can bond two lines. Everything works great, but the main reason for the purchase was the QOS setup options. I’ve tried Simple Queue on a specific device and it probably works fine. I’ve also tried PCQ on the whole network, but I’m not getting the maximum connection speed even though I’m only using one device. I have a 250M download dsl line and only get to 170M max. I am attaching the whole config. So is this a feature or can something be done about it? Thanks.
config1.txt (4.2 KB)
