PCQ Queues
Hello Experts,
I am trying to set a simple Que but it just does not work, my setup is simple, Router with WAN interface and Br on Local LAN.
https://wiki.mikrotik.com/wiki/Manual:Queues_-_PCQ_Examples
I have tried the above example and tried to search for others on Forum but failed to get what I want, not sure where I am going wrong, have tried with 3 routers and all don’t seem to control the que.
Thank you for your time.
Do you have fasttrack enabled? Either disable it or do more specific configuration for fasttrack
Thank you, I only have fast path, no fast track rules. Does Fast path interfere with the PCQ?
