I am having difficulties with setting up rate limit using PCQ’s!
Basically, I am using multiple routers as following:
RB-N → RB-B → RB-A
Each router will provide IP’s by its own, masquerade with it’s pub eth connected to the next router
same again, next router will provide IP’s by its own, masquerade with it’s pub eth connected to main router.
now I have one PCQ running on main router, load balancing connections for each router in the way using “global out”.
how come users on router N, can get higher band than one router before it. and again users on router C will get higher band
than router B ?
… I tried UM profile limitation, but it seems as i need to assign users with ips, if i do that, only first router connected to
main router running UM can get normal communications, the next router in the path will get ip on login, but can’t communicate at all…
most importantly, I would like to have one major PCQ running on main router for all routers connected to it.
taking the fact that routers are connected to routers connected to main routers. like a chain of routers!
Have you checked whether the IP addresses configured in User Manager as NAS IPs have changed? Now that the routers don’t masquerade anymore the RADIUS server may see the clients as different IPs.
ok, this is now urgent… i got all setup fine, but users on 3rd routers can get logged in, but can’t surf…
this is after leaving masquerade on all routers except the main router…
Restore your working configuration to when rate limits weren’t working right so everyone can at least get out.
Then bench out the changes or get a consultant involved. I don’t think a forum can help troubleshoot a network with more than three routers in an adequate timeframe. It looks like both OSPF and RADIUS are misconfigured at this point.
well, all i do to make everything work again is re-enable masquerade on RBs and everything is back to working status.
I don’t think its because of a misconfiguration of UM, I even added the route table for the routers in the sequence in UM, and they do get logged in fine.. but right there, there is no communications with outside world.
its back to normal working status, and if ospf is not an answer to the limitation, what other options are there?
If everything makes it to the final router OK but then cannot go out to the Internet then the final router is misconfigured. Check routing on that router, as well as its NAT configuration.
what is the relationship between DNS and Masquerade?
I requested a user on RB-Step2 to download a large file.
once the connection began and download started, I disabled the Masquerade on RB-Step2 but the download continued till the end.
once the download completed, the user was not able to open pages anymore!
obviously, this test shows that once the connection is established it won’t be interrupted but only new connections are un-replied…
