Hello
I would like to limit my backhauls to a speed as above.
Is this possible?
Do you can download fast or upload fast but if you do both it will be half the speed etc
Hello
Is this possible?
Could you be more specific about the required configuration scenario ?
‘queue simple’ contains ‘total-(limit-at,max-limit, etc.)’, that is applied for entire upload and download traffic.
total-limit=upload+download.
HI ,
Thanks for the info, I’ll look into it.
What I’m on about is putting qos onto my backhauls as I am getting an internet connection faster than they can carry.
If the backhaul has not upload traffic I’d like it to pull faster, but if it has upload traffic use pcq to slow it doen before ping start going west.
I think the total limit will work, I forgot all about that sorry
