PCQ use
I have looked in the archives and manuals and I am still a bit unclear as to how PCQ works.
PCQ = per connection queuing
Ok, knowing that, I will give an example.
I have 5 users that I am queuing with PCQ on MT vs 2.8.18
User 1, User 2, User 3, User 4, User 5
If I set the PCQ download rate at 50,000 bps, and that PCQ included all 5 users, does this mean that if all 5 users downloaded at the same time, they each get 50,000 bps, or do they have to share that 50,000 bps.
Thanks for any answers, I hope I was clear enough,
Leah
If the PCQ rate is set to 50,000 and the Queue is set to 5 x 50,000(250,000) then each of your 5 customers will get 50,000.
If you set the PCQ to 0 and the Queue to 50,000 then your 5 customers will share the 50,000.
Hope this helps.
Rob
