I was wondering if it’s possible to run PCQ limitation on the router running UM rather than UM itself handling limitation?
If yes - Then what’s the best approach for the below:
In a network with 10’s of routers linked back to one main router - should mangle and pcq be set on each router or
just on main router? The point in mind is the equal band sharing between active users, and I am not sure if say,
one router has 1 active user and another router has 50 active users. Will the band be divided per router or per
user if “global-out” was set as parent in the tree?
Furthermore, there are routers that are not directly linked to the main router, but through another router in the path!
So, would “global-out” handle band equalization per user not per device? if not - then what are other recommendations?
THX
