PCQ with PCC method...
i had seen the PCQ method, but i am not understand about it..
i want to dynamic Equal Bandwidth to the user, it mean it will automatic arrange the speed of the active user…
how can i do it?
i had change the “pcq pcq-rate=0”, how do the ROS know my incoming bandwidth from ISP so that it can set the equal bandwidth?
and i am using load balancing method..
Port 1 and 2 is my ISP, and port 3 is for output LAN..
how can i make the users which from LAN can dynamically have equal bandwidth base on active user?
PCQ coding…
/ip firewall mangle add chain=prerouting action=mark-packet
in-interface=ether1-LAN new-packet-mark=client_upload
in-interface=ether2-WAN new-packet-mark=client_download
/queue type add name=“PCQ_download” kind=pcq pcq-rate=0 pcq-classifier=dst-address
/queue type add name=“PCQ_upload” kind=pcq pcq-rate=0 pcq-classifier=src-address
/queue tree add parent=global-in queue=PCQ_download packet-mark=client_download
/queue tree add parent=global-out queue=PCQ_upload packet-mark=client_upload
PCC load balancing coding
/ ip address
add address=192.168.0.1/24 network=192.168.0.0 broadcast=192.168.0.255 interface=LAN
add address=192.168.1.2/24 network=192.168.1.0 broadcast=10.111.0.255 interface=ISP1
add address=192.168.2.2/24 network=192.168.2.0 broadcast=10.112.0.255 interface=ISP2
/ ip firewall mangle
add chain=prerouting dst-address=192.168.1.0/24 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.2.0/24 action=accept in-interface=LAN
add chain=prerouting in-interface=ISP1 connection-mark=no-mark action=mark-connection
new-connection-mark=ISP1_conn
add chain=prerouting in-interface=ISP2 connection-mark=no-mark action=mark-connection
new-connection-mark=ISP2_conn
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local hotspot=auth
per-connection-classifier=both-addresses:2/0 action=mark-connection new-connection-mark=ISP1_conn
per-connection-classifier=both-addresses:2/1 action=mark-connection new-connection-mark=ISP2_conn
add chain=prerouting connection-mark=ISP1_conn in-interface=LAN action=mark-routing
new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=LAN action=mark-routing
new-routing-mark=to_ISP2
add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
/ ip route
add dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-mark=to_ISP1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 routing-mark=to_ISP2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.1.1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=192.168.2.1 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=ISP1 action=masquerade
add chain=srcnat out-interface=ISP2 action=masquerade
