PC's upstream from hotspot needed to be access from hot spot
Hi there.
here is a simple network diagram of what i am trying to do here.
ether 1 goes to my modem, ether 2 (192.168.1.0/24 range) goes to a switch with my PBX, NAS, and web server ( these need to have open access to the internet(as if it was a normal home network)
Ether 3 (10.5.50.0/24 , 192.168.10.0/24 range) has PPPoE server and hotspot on, Now the thing is i need the clients to be able to access the Devices on ether 2. But if i bridge ether 2,3 then the servers get gouverend by hte hotspot and their internet does not work?
I have tried adding a static route with destination add 192.168.1.0/24 to ether 2. but then my access to my servers comes and goes (its very strange) What is the correct way that i should go about doing this?
Network Diagram:
Add the resources customers should have access to without being logged in to the walled garden IP section of the Hotspot.
http://wiki.mikrotik.com/wiki/Manual:IP/Hotspot#ip_hotspot_walled-garden
Is that not only for http services?
Will the PPPoE clients also be able to access it?
And then do i need any routes or any thing setup?
From the very link I posted:
ip hotspot walled-garden ip
Walled-garden menu for the IP requests (Winbox, SSH, Telnet, SIP, etc.)
PPPoE has nothing to do with Hotspots.
If both networks are directly connected to the router, it has routes to each destination, so why would you need to set up extra routing for this?
Oh ok i see.
So then ether 2 must just have a ip address on it and that it???
Oh ok i see.
Yes.
Thanks i will give it a try and let u know.
:smiley:
Can the lan users then access the pc being the PPPoE?
if i have a rb750 and all ports are swiched and then i have a few clients conencted via PPPoE.
How can i set it up so that the computers on the ethernet interface can access the computers on the PPPoE server interface
