Any chance of winbox support for PDA’s/Pocket PC running Windows Mobile or Symbian?
That would be great! Runing PocketPutty at the moment, but for quick checks WM5 Winbox would be awesome!
B)
B)
they already work with the web config interface. winbox will not be supported. we will make the API available sometime soon, then you will be able to make your own programs
hi normis
how far away is the API so we can run winbox on our pocket pc’s?
WinBox as it is would be tight on the PPC. Easier to use VNC or RDT to a pc running WinBox. Looking very forward to the API.
Regarding WebBox, that would be a good tool on any platform if it could be customized. As it is now - just hit the hotspot auto setup by mistake. Whole system down the tubes.
Mike
