Please support this feature request.
Exactly in Russia Rostelecom now deployed APs this PEAP authentication and MT user not able to connect to such ISPs.
(особенно для тех, кто уже столкнулся с УЦН и невозможностью подключиться на родном оборудовании).
Last answer from support was
currently we do not support WAP-EAP PEAP as wireless station in RouterO
We will look if we could add this support in future, but it might not happen so fast as we haven’t received lot of request for such feature.
I believe that it needed feature, please leave comment (vote) if You need it too.
I completely agree, this is the most widespread method for authenticating with username/password and sometimes we can’t change (since we’re connecting to the network we have no control over).
I bought SXT Lite 2 and much to my surprise can’t use it since I need WPA2-EAP-PEAP-MSCHAPV2 support.
MikroTik, please add this feature which is present in most other OS (OpenWRT etc).
I would like to see it as well, it certainly would make our WiFi network a lot easier to manage.
No idea how much work it would involve, I think the underlying software already supports it, it is mainly a configuration issue.
(adding some fields, setting parameters for the underlying software)
we were able to improve the compatibility with the PEAP and in one of the next RC versions it will be added - just check the changelog entry and then test that version.
After than please report back if it works ok.
I need to test it but it is a bit difficult as I don’t have a MikroTik as station myself.
So I need to get remote access to someone else’s device and be able to experiment without losing the connection.
Maybe later.
No of course not, I am a user. But at home I have a Ubiquiti AP. There it works.
Other people in our network have MikroTik and I need to debug via one of their APs.
