Peer DNS
In the PPTP Client settings, there is an option “Use Peer DNS”, where you can choose “yes”, “no” and “exclusively” - what is the difference between “yes” and “exclusively”?
Yes add the DNS with the other already configured or acquired from other sources,
Exclusively ignore all other DNS and use only PPtP DNS, for avoid DNS leaking to other connections.
