Peninsula Problem - Turnkey Package
I plan on starting a WISP on a Peninsula
I need to cover a 15 x 1 mile area.
LOS is not a major problem because the houses are on stilts due to flooding.
Can you suggest a antenna that fit my needs?
Is the routerboard 500 faster than the 200 series?
Is the PC setup better than the routerboard setup?
I care more about quality, performance and expandability than price.
Can anyone quote me a turnkey package in America?
Thanks.
HI,
You can use all systems board that you want or you have availables on your country. For solve problem NLOS I suggest you to use 5GHz band with OFDM modulation and DFS mode.
For solve problem of reflection into the city I suggest you to use directional antenna with dipole in circolar polarization.
For wireless data applications the antenna is heart of the system. If you want more informations don’t esitate to contact me.
Regards
Xandor
