I have an RB450G and I would like to shape on LAN interfaces without MAC or IP address.
For example shape the whole traffic of ether3 interface to 2Mbps/4Mbps up/down.
It is possible? It could work?
Thx,
oreggin
Thx,
oreggin
Sure. Put a queue tree rule as follows:
/queue tree add name="ether2" parent=ether2 limit-at=2000000 priority=8 max-limit=0 burst-limit=0 burst-threshold=0 burst-time=0s
limit-at format is in bits/seg,
ether2 is an example: put your own interface here.
This limits are ever applied in outgoing traffic of the interface.
Shouldn’t it actually be “max-limit”?
limit-at should be empty in this case
yes, you’re right. My mistake.
THX, I will try.
This isn’t working on wlan1 interface for example, but works on bridge1.
Sorry, I forgot: It was tested on ROS v5beta6
If you are using bridges, be sure to enable IP firewall in the bridge settings.
I have a RB433AH with an 11n wireless miniPCI card and use 5.0rc1 ROS.
If I enable any queue on wlan1 (which isn’t member port of bridge1), on the ether2 and ether3 port (which are member ports of bridge1) DNS resolving is slow (~5000msec). If I disable the queue DNS resolving is fast again ~50-100ms.
If I enable any queue on bridge1 (which have member ports of wlan1, ether2, ether3), on the ether2 and ether3 port (which are member ports of bridge1) DNS resolving is slow (~5000msec). If I disable the queue DNS resolving is fast again ~50-100ms.
Interesting but on clients on wlan1 interface DNS resolving isn’t slow any of the scenarios above.
The use-ip-firewall bridge settings doesn’t affect the result.
Any idea?
This queue is doesn’t any effect with this setting:
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=8700k max-limit=10M name=wifi parent=wlan1 priority=8 queue=default
Edit: wlan1 is not a member oprt of bridge1 and no any opther queue on the system.
Any idea?
disable ipv6 in browser → faster dns resolving with queueing with bridge
Dears,
Can this be done through GUI or it’s just via CLI?
Dears,
Why are you reviving a topic from 2010?! Come on.
Also the question, you can easily look this up with just a bit of googling or trying. The answer is, this can be done through winbox, web interface and cli.
