So we have 2 line
wan 1= 200M
wan 2=50MB
Traffic = 50% from wan1 and 50% from Wan2
Need Edit Rule to set load balance 70% from Wan 1 and 30 Form Wan 2
THANK
Current config
add action=mark-connection chain=prerouting dst-address-type=!local
new-connection-mark=WAN_CON_1 passthrough=yes per-connection-classifier=
both-addresses-and-ports:2/0 src-address=192.168.88.0/24
new-connection-mark=WAN_CON_2 passthrough=yes per-connection-classifier=
both-addresses-and-ports:2/1 src-address=192.168.88.0/24
add action=mark-routing chain=prerouting connection-mark=WAN_CON_1
new-routing-mark=ROUTING1 passthrough=yes src-address=192.168.88.0/24
add action=mark-routing chain=prerouting connection-mark=WAN_CON_2
new-routing-mark=ROUTING2 passthrough=yes src-address=192.168.88.0/24
66% = 1/3->1 2/3->1 3/3->2
So good
why is 3/1 3/2 3/3
why not 3/0 3/1 3/2
can you help me to write the addistional rule i need
Even simpler: 1/3 goes to two and the rest goes to one.
You so only need one PCC line that marks traffic for routing2 and the rest you just mark for routing1 as long it is not marked earlier for routing2.
both-addresses-and-ports:3/0 src-address=192.168.88.0/24
connection-mark=!WAN_CON_2 new-connection-mark=WAN_CON_1
Bye
Wan1 5/0
Wan1 5/1
Wan1 5/2
Wan1 5/3
Wan2 5/4
Using PCC
@chechito: really? Secondly, that is 80:20
Simpler, 5/4 to Wan2 what is left to Wan1.
Do you now get, how it can work?
Bye
wich the correct answer??
You can be the judge on that.
anav
9
Chechito had the right idea actually just didnt take it far enough.
WAN2 - 7/0
WAN2 - 7/1
WAN1 - 7/2
WAN1 - 7/3
WAN1 -7/4
WAN1 - 7/5
WAN1 - 7/6
To use Msatters cute but not fully explained shortcut…
both-addresses-and-ports:7/0 src-address=192.168.88.0/24
both-addresses-and-ports:7/1 src-address=192.168.88.0/24
