Perfect CPE Disc Lite5 or SXT lite5 or LHG 5
Hi all Routerboarders
I need information and comparisons between this CPE
for Ptmp which device we should use?
Currently I’m using SXT lite 5 but I’m not totally satisfied..
So please give your opinion
You can find information and comparisons between radios on www.routerboard.com
Also
https://i.mt.lv/routerboard/files/antenas-mantbox-160404123306.pdf
and
https://i.mt.lv/routerboard/files/antenas-160404123306.pdf
on the same web page…
You don’t need someone to tell you that one has bigger antenna than other. The more gain, the better.
The disc lite works better then the sxt’s from our experiance.
Use them if your signal is below -65 on all chains.
If its not rater use the LHG and it that doesn’t work the trusty old groove with a 27dbi grid and feed should solve the problem
