I am happy user of RB750Gr3 router I have recently upgraded to 7.1.1 and saw both performance decrease and IPv6 issues. Then I downgraded back to 6.49.2 and all issues are gone.
RouterOS 7.1.1:
download: max 210 Mbps, 150 Mbps if I limit CPU frequency to 600 MHz
IPv6 packets are lost, but router gets prefix from DHCPv6 and propagates it with SLAAC
RouterOS 6.49.2:
download: max 600 Mbps (limited by ISP)
IPv6 working just fine
Configuration:
/export
# jan/20/2022 22:13:20 by RouterOS 6.49.2
# software id = 6T18-UE1J
# model = RB750Gr3
# serial number = xxx
add admin-mac=xxx auto-mac=no comment=defconf name=bridge protocol-mode=none
set [ find default-name=ether1 ] arp=disabled
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
/interface vlan
add arp=disabled interface=ether1 mtu=1492 name=orange vlan-id=35
/interface pppoe-client
add add-default-route=yes disabled=no interface=orange keepalive-timeout=disabled name=pppoe password=xxx use-peer-dns=yes user=xxx@neostrada.pl
add add-default-route=yes disabled=no interface=orange keepalive-timeout=disabled name=pppoe-ipv6 password=xxx use-peer-dns=yes user=xxx@neostrada.pl/ipv6
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool1 ranges=10.0.0.100-10.0.0.254
add address-pool=dhcp_pool1 disabled=no interface=bridge lease-time=10h name=dhcp1
/port
set 0 name=serial0
add comment=defconf interface=pppoe list=WAN
add address=192.168.1.2/24 interface=bridge network=192.168.1.0
add address=10.0.0.1/24 interface=bridge network=10.0.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-server config
set store-leases-disk=never
/ip dhcp-server lease
add address=10.0.0.253 client-id=xxx mac-address=xxx server=dhcp1
add address=10.0.0.0/24 dns-server=194.204.152.34,194.204.159.1 gateway=10.0.0.1
add action=dst-nat chain=dstnat dst-port=23784 protocol=tcp to-addresses=10.0.0.5
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=10.0.0.0/24
set ssh port=27364
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ipv6 address
add address=xxx eui-64=yes from-pool=orange interface=bridge
/ipv6 dhcp-client
add add-default-route=yes interface=pppoe-ipv6 pool-name=orange pool-prefix-length=56 request=prefix
/ipv6 nd
set [ find default=yes ] interface=bridge
/system clock
set time-zone-name=Europe/Warsaw
/system scheduler
add disabled=yes interval=10m name=ip on-event=ip policy=read,write,test start-date=oct/01/2021 start-time=21:15:20
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=bridge filter-ip-address=xxx/32 streaming-enabled=yes streaming-server=10.0.0.253
You don’t have any firewall rules - that isn’t a secure configuration.
Check system->resources->CPU results when you are doing the speedtest. If a CPU is hitting 100%, use tool profile during the same test to try to determine what process is using the high utilization.
It is also good to compare this between v6 and v7.
Using the default route on pppoe client AND on dhcpv6 client will not work on v7, it used to work on v6 due to a bug.
Disable the default route on the dhcpv6 client.
Regarding the performance, yes, it’s bad on v7
I said to check /system/resource/cpu/print, which shows the per core utilization. You are looking at the average usage of all cores with /tool/profile, which is useless in determining if a single core is overloaded. Although you can use /tool/profile, you have to use “/tool/profile cpu=all” in order to see the per-core usage, and not just the regular /tool/profile.
We have argued with MikroTik that they should add new data to the performance figures on their older products, at least those that are still for sale, when used with RouterOS v7.x instead of v6.x.
The published figures for products that were designed and released with v6 are all for running with v6 (although this is not indicated).
They sort of agree, but of course it is a lot of work and will not happen immediately.
It is a “known fact” that performance with v7 is less than with v6. That of course for new devices is compensated by the fact that these are faster anyway, but when you have an old device you really should consider whether you need the new functionality of v7, and if not you should consider to remain on v6 when performance is important for you.
