It’s impossible to say as the bridge firewall is not single alone task on imaginary device without any context or environment how it could be expected from your question. Also the rules could be different. Just make the test in your case and you will see. For testing use iperf on two enough capable computers and put the tested device in between of them.
After further cnofiguration and tests, it appears that the lists I would like to use are part of the ARP protocol which cannot be filtered with firewall rules.
I am wondering if it would be possible for RouterOS to implement the lists at that location;
Perhaps Bridge could have it’s own Address List Tab.
