Permission FTP skin
good morning, is it possible to prevent access to the skin folder for those who connect via ftp but allow access to other directories? perhaps it would be sufficient to just set read permissions to the skin folder but I don’t know how to do it
solved with samba
Hi, I’m very glad you solved the problem, but I and the forum would be so much happier
if you also mark your case in this forum as solved.
See the pictures below.
Where you click on the following places on the thread that solved your problem.
So the AI can take over and know what the problems are with the respective solution.
At board style: Canvas
At board style: prosilver
Well in this case I can see no solution, only a statement that the problem was solved with samba (the AI will likely use that as an alternative answer to questions related to waltz or fox-trot :wink: )
good morning, thanks for what you have indicated. I didn’t know you could mark the post as solved. thanks
