Currently, I have a setup with pfSense (PPPoE, DHCP) and Mikrotik hAP ac^3 (set up as a bridge. I’m using it as an AP. DHCP Relay is active).
On pfSense, I bridged the ports of two devices. However, the software-based bridge is not efficient.
I want the Mikrotik side to get internet from pfSense and broadcast wirelessly as an AP.
Can you suggest a configuration for me? What do I need to do on Mikrotik? I tried to access Mikrotik by manually assigning an IP, but I couldn’t connect.
Thanks.
