I have been happily using my Philips Hue for some time until the change from ISP modem to Mikrotik, now I am only able to access the Hue Bridge from inside the network not outside.
I don’t believe that forwarding is necessary, it wasn’t before. Hue bridge is at 192.168.1.118
Hue sits on Ether7
> /export
# oct/13/2019 20:10:27 by RouterOS 6.45.6
# software id = xxxxx
# model = 2011UiAS
# serial number = xxxxxxxxx
add admin-mac=D4:xxxxxxxx auto-mac=no comment=defconf name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 password=xxxxxxxxxxxxxx user=xxxxxxxxxxxxxx
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf disabled=yes interface=ether5
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
/interface detect-internet
set detect-interface-list=all
add address=192.168.1.1/24 comment=defconf interface=ether2 network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1 use-peer-dns=no
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes cache-size=4096KiB servers=208.67.222.222,208.67.220.220
/ip dns static
add address=192.168.1.1 name=router.lan
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat disabled=yes dst-address=xxxxxxxxx dst-port=xxxx protocol=udp to-addresses=192.168.1.xx to-ports=xxx
add action=dst-nat chain=dstnat disabled=yes dst-address=xxxxxxxxx dst-port=80 protocol=tcp to-addresses=192.168.1.118 to-ports=80
add action=dst-nat chain=dstnat dst-address=xxxxxxxxx dst-port=80 protocol=udp src-port="" to-addresses=192.168.1.118 to-ports=80
add action=dst-nat chain=dstnat dst-address=xxxxx6 dst-port=xxxxx protocol=udp to-addresses=192.168.1.xxx to-ports=xxx
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/lcd
set backlight-timeout=never default-screen=stats-all
/system clock
set time-zone-name=Europe/London
/system logging
add prefix=PPPoE topics=pppoe
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=ether1
Have I missed something in the firewall?
