Hi guys.
Im trying to authorize a client on my hotspot through the api using php client like:
<?php
require(dirname(__FILE__).'/routeros-api/routeros_api.class.php');
$host = '192.168.89.1';
$API = new RouterosAPI();
$API->debug = false;
$API->timeout = 1;
$API->attempts = 3;
ob_start();
if ($API->connect($host, 'api_user', 'api_user')) {
$API->comm("ip/hotspot/active/login/", array(
"user" => "user",
"password" => "user123",
"mac-address" => "C0:17:4D:B3:F7:1F",
"ip" => "50.1.1.199",
$READ = $API->read();
$READ = $API->read(false);
$ARRAY = $API->parseResponse($READ);
print_r($ARRAY);
$API->disconnect();
unset($API);
ob_end_clean();
For some reason this is not working ,
I have no output.
There is no problem with the code , replacing the API->comm method parameter for something like (/ip/arp/print) it works.
I dont know how to debug this …
Any idea ? Is there another way ?
Thanks!
