PHP API Question
Hey guys,
I’m trying to use PHP to disable and enable a route with this code:
$API = new routeros_api();
	if ($API->connect($RBIP, 'admin', 'password'))
		$ARRAY = $API->comm('/ip/route/print
							?=dst-address=0.0.0.0/0');
		if ($ARRAY[0][disabled] == 'false')
			$API->write('/ip/route/set', false);
			$API->write('.id='.$ARRAY[0]['.id'], false);
			$API->write('=disabled=true');
			$API->write('!done');
			popMsg("Disabled Internet");
		 else
			$API->write('=disabled=false');
			popMsg("Enabled Internet");
		$API->disconnect();
	 else
		echo 'Unable to connect to RB';
Could you please point me in the right direction as to why it isn’t working?
what responses you are getting from API?
