xezen
1
i run this code 2 times but i want to clean it up run it one time with 2 ip
192.168.87.1
and
192.168.87.2
can someone help me with this maybe on how to do it 2 set 2 values for 1 verable
<?php require_once('api_mt_include2.php'); ?>
<?php
$ipRouteros="192.168.87.1"; // tu RouterOS.
$Username="apilinks";
$Pass="api";
$api_puerto=8728;
$API = new routeros_api();
$API->debug = false;
if ($API->connect($ipRouteros , $Username , $Pass, $api_puerto)) {
$API->write("/system/ident/getall",true);
$READ = $API->read(false);
$ARRAY = $API->parse_response($READ);
$name = $ARRAY[0]["name"];
if(count($ARRAY)>0){ // si esta conectado
$API->write("/system/licen/getall",true);
$nlevel = $ARRAY[0]["nlevel"];
$API->write("/system/reso/getall",true);
$cpu = $ARRAY[0]["cpu"];
$cpu_frequency = $ARRAY[0]["cpu-frequency"];
$arquitectura = $ARRAY[0]["board-name"];
$API->write("/system/pack/getall",true);
$version = $ARRAY[0]["version"];
echo '
echo "
".$name."(" .$arquitectura. ") ";
echo "v:" . $version. " ";
echo "level:" . $nlevel . " ";
echo $cpu."(".$cpu_frequency." Mhz.)";
}else{ //el servidor API esta of line
echo '
'.$ARRAY['!trap'][0]['message'];
}else{
echo "La conexion ha fallado. Verifique si el Api esta activo.";
$API->disconnect();
echo
$ipRouteros="192.168.87.2";
$Pass="api";
$api_puerto=8728;
echo '
echo "
echo '
}else{
$API->disconnect();
Write the credentials in an array, and loop over it.
So instead of
<?php
$Pass="api";
$api_puerto=8728;
//Junk #1
$Pass="api";
$api_puerto=8728;
//Junk #2
Make that
<?php
$routers = array(
array('192.168.87.1', 'apilinks', 'api', 8728),
array('192.168.87.2', 'apilinks', 'api', 8728)
foreach ($routers as $router) {
$ipRouteros = $router[0];
$Username = $router[1];
$Pass = $router[2];
$api_puerto = $router[3];
//Junk
