I would like to enable or disable interface through API. I have created PHP code which should do it, but U have a porblem when I enable one interface and try to get information about another interface, API returns empty array. I tried to put sleep() function, but I is not working.
You must either read() before very write (even if you don’t care about the reply’s contents) or you must add a “.tag” when writing, and when reading, loop through the replies until you find the tag you had set when writing.
Or at least, that is what must happen on a protocol level. With the API client from my signature, this is taken care of in the background.
But… in all honesty, I think your algorithm is very much suboptimal… You don’t need the IDs of interfaces - you can use the names with “enable” and “disable”. Furthermore, you can separate multiple names with a comma. The only reason you may want to use an ID instead is if the name contains a comma.
With all of that in mind, here’s an optimized version with the API client from my signature:
<?php
use PEAR2\Net\RouterOS;
require_once 'PEAR2_Net_RouterOS-1.0.0b5.phar';
//Init $apMap here or in an external file that includes this one, or is included here; also $dilna and $run
$apMap["Group1"][0] = "AP1";
$apMap["Group2"][0] = "AP2";
$apMap["Group3"][0] = "AP3";
$apMap["Group4"][0] = "AP4";
$util = new RouterOS\Util($client = new RouterOS\Client('192.168.103.86', 'API', 'YN@tpmjm7.p98th@'));
$util->setMenu('/caps-man/interface');
if ($run) {
$util->enable(implode(',', $apMap[$dilna]));
} else {
$util->disable(implode(',', $apMap[$dilna]));
or if you prefer to be name agnostic (i.e. support interface names with a comma) at a slight performance penalty (but still more efficient than your original code):
<?php
$query = RouterOS\Query::where('name', $apMap[$dilna][0]);
for ($i = 1, $l = count($apMap[$dilna]); $i < $l; ++$i) {
$query->orWhere('name', $apMap[$dilna][$i]);
if ($run) {
$util->enable($query);
} else {
$util->disable($query);
Thanks for response boen_robot. But when I reenable AP it will kick of all users which are connected to AP. This is reason why I read if the AP is active or not.
But OK… As a workaround (I mean, even if they fix this in the next version, I’m sure you’ll want to keep supporting older ones for a while):
<?php
$query->andWhere('disabled', ($run ? 'true' : 'false'));
if ($run) {
} else {
When enabling, this will match only disabled interfaces, and when disabling, it would match only enabled interfaces.
