Physical and vlan interface
Hi all,
I just want to know if there is a side effect if you put ip on physical interface while having vlan interfaces with ip also. I know the common practice is to keep physical interface empty and put ip only on vlan interface. Thanks
Not a problem. Ros takes those interfaces separately from the L3 point of view.
Thanks man!
