I'm trying to find a cost-effective switch for use in a one-room office that currently uses 10GbE (mostly UTP) with a QNAP 4-port SFP+/RJ45 and 8-ports of 1G, and I added a NICGIGA 8-port 10GBASE-T switch when we added more 10G machines. This system can easily run at 10G wire speeds, but we're looking to go faster to make editing in Resolve and FCP smoother (and maybe allow multiple machines to access the file server at the same time).
We've found an issue with using an M4 Mac Studio as the SMB server with two DAS units on TB3 that affects network-share performance. So we're looking at upgrading to a NAS which will have an SFP+ port initially to connect to the QNAP switch <1m away, and with a pair of M.2 SSDs to cache data from the 8-drive RAID5, we can get >10G speeds. This would require either 25GbE or 40GbE, with the former having a couple of "compatible" PCIe cards available and the latter listing an EOL card.
So I need either a 25G switching solution or a 40G solution with ALSO has 10G connectivity back into the rest of the network. In other words, the Studio, the M4 MBP, and the NAS will all be connected to the switch at one of this link rates, BUT the switch needs to connect into the rest of the network [ROW] at 10G. The first MikroTek switch I found that comes close is the CRS504-4XQ-IN, but it does not have a [single] 10G port for the ROW interface. The QSFP28 ports can accommodate a breakout cable to give me four 25G ports each--which I would use for my three devices--but there is also the following statement:
In fact, you can mix and match all kinds of connections this way: 100 Gigabits on one port, 40 Gigabits on the other, 4x25 Gigabits on the third, and maybe even some 10G or 1G cables on the fourth.
I tried to verify this in the start up guide and the product manual, but they have no info (so I guess it's simply in the RouterOS manual?). Maybe a 10G/40G breakout cable with a 40G module is what's necessary? Or is it an oversight on the webpage?
As you can tell, I'm kind of a networking n00b at these link rates, and mostly a HW engineer. Thanks in advance for answers.
