PiHole / alternate DNS config issue
I set up my Hex S this week to replace an old Asus home router. Really impressed so far and have got my head around the basics.
I’m struggling with routing DNS queries through my PiHole though which is on a static IP of 192.168.1.2 (I use 192.168.1.0/24 for my network). I put the PiHole IP into the DNS section under the DHCP server and untick “use peer DNS” on the interface. At this point, the connection falls over with a constant repeat of connecting…terminating - unable to obtain IP address…etc
The router gets stuck in this loop and will not recover from it. The only way I have found is to ‘reset configuration’ and start all over again. If I reset then restore a known working backup, the connection issue comes back so it will only work again if I manually rebuild the config/rules again. Slightly frustrating!
My guess is that the interface is getting stuck in some sort of unobtainable loop. The PiHole works fine if I manually configure the DNS on a device (eg mobile phone)
My guess is that it must be a firewall config issue. I’ve followed the Mikrotik guidance to pretty well lock down my firewall so I’m guessing I might need to either pass through port 53 or add the PiHole IP to one of my firewall rules.
Can anyone help narrow the issue down?
Thanks.
# sep/06/2020 19:34:44 by RouterOS 6.47.3
# software id = MW9G-YJBZ
# model = RB760iGS
# serial number = ############ (*removed*)
/ip firewall address-list
add address=192.168.1.2-192.168.1.254 list=allowed_to_router
add address=192.168.2.2-192.168.2.100 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
    not_in_internet
add chain=input port=1701,500,4500 protocol=udp
add chain=input protocol=ipsec-esp
add action=accept chain=input src-address-list=allowed_to_router
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=input comment="default configuration" \
add action=drop chain=input
add action=fasttrack-connection chain=forward comment=FastTrack \
add action=accept chain=forward comment="Established, Related" \
add action=drop chain=forward comment="Drop invalid" connection-state=invalid \
    log=yes log-prefix=invalid
    "Drop incoming packets that are not NATted" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1 log=yes log-prefix=!NAT
    "Drop incoming from internet which is not public IP" in-interface=ether1 \
    log=yes log-prefix=!public src-address-list=not_in_internet
