I have currently a test machine with ROS installed, when I remove HDD and migrate to PII the Atheros PCI card is not found, but on returning both Wireless PCI card and HDD to the P4 it works fine.
I would like to use the PII for the router and the P4 for another use, but am unable to get the wireless card working on the PII machine. Is there a way to force detection of atheros wifi card?
Are you sure that your PII motherboard support the PCI 2.2 standard (3.3V signaling)?
If i’m not in wrong, that standard was supported since PIII “age”.
