PIM - IP Tv
(MikroTik RouterOS 6.40.4 (RouterBoard 750)
I need help with the PIM or IGMP Proxy settings
I do not know the well Mikrotik routers, only the basic settings.
The situation is the following:
From Triax central ( IP TV Signal), I have a connection to port 3 on Mikrotik
Ip TV Signal works well, because I tried to directly connect to my computer use VLC Player
The programs are the following ip udp://@232.10.0.11:5005 232.10.0.12 …
To make it work on my computer, I set up the following settings. Computer IP 192.168.100.50/ Gw 192.168.100.20
So there’s a port on Trix 192.168.100.20.
So port 3 on Mikrotik must have ip 192.168.100.50 ??
Next :
I like to send this IP signal from port 3 to port 4. On port 4 I switched LG ProCentric Server
For distribution IP TV to LG Screens on a small hotel (20 screens)
IP address of port 4 is not important
I’d like to ask anyone for help.
How do I set the correct configuration to work?
Thanks for the help,
S.
You can follow this guide to setup igmp-proxy: https://wiki.mikrotik.com/wiki/Manual:Routing/IGMP-Proxy
Post your configuration if you will still have problems with igmp-proxy configuration:
export hide-sensitive compact
