pim JoinDesired warning
I need help about these warning :
19:28:47 pim,warning JoinDesired(S,G) = false: upstream neighbor for source 192.168.88.1 and group 239.255.255.250: not found
19:28:48 pim,info Added new address to interface Server: 192.168.88.1/30
19:28:48 pim,info PIM interface started: Server
19:28:48 pim,info IGMP interface started: Server
19:29:01 pim,info PIM interface stopped: Server
19:29:01 pim,info IGMP interface stopped: Server
19:29:01 pim,warning JoinDesired(S,G) = false: upstream neighbor for source 192.168.88.1 and group 239.255.255.250: not found
19:36:46 dhcp,info dhcp-server deassigned 192.168.88.2 from 00:24:1D:8E:84:E4
20:36:35 pim,info Added new address to interface Server: 192.168.88.1/30
20:36:35 pim,info PIM interface started: Server
20:36:35 pim,info IGMP interface started: Server
20:38:33 pim,info PIM interface stopped: Server
20:38:33 pim,info IGMP interface stopped: Server
20:38:33 pim,warning JoinDesired(S,G) = false: upstream neighbor for source 192.168.88.1 and group 239.255.255.250: not found
20:41:51 pim,info Added new address to interface Server: 192.168.88.1/30
20:41:51 pim,info PIM interface started: Server
20:41:51 pim,info IGMP interface started: Server
20:48:10 pim,info PIM interface stopped: Client
20:48:10 pim,info IGMP interface stopped: Client
20:48:10 pim,warning JoinDesired(S,G) = false: upstream neighbor for source 192.168.66.1 and group 239.255.255.250: not found
20:48:10 pim,warning JoinDesired(S,G) = false: upstream neighbor for source 192.168.66.2 and group 239.255.255.250: not found
20:52:12 pim,info Added new address to interface Client: 192.168.66.1/30
20:52:12 pim,info PIM interface started: Client
20:52:12 pim,info IGMP interface started: Client
my pim interfaces :
[admin@local] /routing pim interface> pr
Flags: X - disabled, I - inactive, D - dynamic, R - designated-router, v1 - IGMPv1, v2 - IGMPv2, v3 - IGMPv3
 #      INTERFACE                                               PROTOCOLS
 0  Rv2 Server                                             pim
        igmp
 1  Rv2 Client                                             pim
        igmp
 2 DR   register                                                pim
pim rp :
[admin@local] /routing pim rp> pr
Flags: D - dynamic, X - disabled
 #    ADDRESS         TYPE      PRIORITY
 0    192.168.66.1    static    192
pim mrib :
[admin@local] /routing pim mrib> pr
 #   DESTINATION        GATEWAY         METRIC INTERFACE
 0 D 0.0.0.0/0          192.168.1.1     1       Wan
 1 D 192.168.1.0/24     0.0.0.0         0      Wan
 2 D 192.168.55.0/29    0.0.0.0         0      House
 3 D 192.168.66.0/30    0.0.0.0         0      Client
 4 D 192.168.77.0/30    0.0.0.0         0      Squid
 5 D 192.168.88.0/30    0.0.0.0         0      Server
 6 D 192.168.99.0/28    0.0.0.0         0      Hotspot
pim mfc :
[admin@local] /routing pim mfc> pr
GROUP           SOURCE          RP
239.255.255.250 192.168.66.2    192.168.66.1
239.255.255.250 192.168.88.1    192.168.66.1
pim join :
[admin@local] /routing pim join> pr
Flags: RP - (*,*,RP), WC - (*,G), SG - (S,G), SG_rpt - (S,G,rpt)
       GROUP           SOURCE          RP
    WC 224.0.0.0       192.168.66.1    192.168.66.1
    SG 239.255.255.250 0.0.0.0         192.168.66.1
SG_rpt 239.255.255.250 192.168.66.2    192.168.66.1
SG_rpt 239.255.255.250 192.168.88.1    192.168.66.1
pim igmp-group :
[admin@local] /routing pim igmp-group> pr
Flags: v1 - IGMPv1, v2 - IGMPv2, v3 - IGMPv3, I - include, E - exclude, F - forward, D - don't forward
    INTERFACE                                                     GROUP           SOURCE          TIMEOUT
v2E Server                                                   224.0.0.2       0.0.0.0         3m14s
v2E Server                                                   224.0.0.13      0.0.0.0         3m15s
v2E Server                                                   224.0.0.22      0.0.0.0         3m8s
v2E Server                                                   239.255.255.250 0.0.0.0         3m10s
v2E Client                                                   224.0.0.2       0.0.0.0         3m9s
v2E Client                                                   224.0.0.13      0.0.0.0         3m10s
v2E Client                                                   224.0.0.22      0.0.0.0         3m9s
v2E Client                                                   239.255.255.250 0.0.0.0         3m3s
I just need to ‘join’ client and server interface together both upstream and downstream to each other, specifically udp, all works fine but as you can see above, it throws the warning :frowning:, please help to eliminate the warning :slight_smile:.
anyone can help?
can you see router in neighbors? also, what version you are using?
have you tried to reboot router when applied the settings?, have you tried to reboot other routers in the multicast cloud?
yes both of the device can see the router, hmm, it’s only 1 router used, in simple word i wanted to interconnected 2 devices from 2 different subnet which is these 2 :
The purpose of ip routing pim can be applied for my case right? or i get the concept wrong?. My topology
    Mikrotik RB 1100
   Client     Server
hmm.. you have to set only 2 interfaces and rp for this to work in either direction even if you have nat in between.
yes i have set the interface only 2, server and client but somehow mikrotik added another available online interface into /routing pim mrib
Both client and server has internet access, could be one of the reason mikrotik adding more mrib? , how to stop mikrotik automatically adding these?
they are taken from routing table, it is not possible to change that.
