PIM problem
Good day. There are two uplink with IPTV from different ISP. I trying to set up PIM. And when I up PIM-interface, the router subscribes to all available multicast groups and, as a result, corrupts the channel. Should it work this way, or there is a bug in the implementation of the protocol? Or may be it is mistake in configuration? Thanks.
Can you post the pertinent configuration for review? There are a number of possibilities that could be causing your issue.
Thanks,
 > routing pim interface print
Flags: X - disabled, I - inactive, D - dynamic, R - designated-router, v1 - IGMPv1, v2 - IGMPv2, v3 - IGMPv3
 #      INTERFACE        PROTOCOLS
 0   v3 IPTV-NSK        igmp
 1   v3 IPTV-SS        igmp
 2   v3 bridge        igmp
> routing pim rp print
Flags: D - dynamic, X - disabled
 #    ADDRESS         TYPE        PRIORITY
 0    192.168.88.1                     192
