PIM Routing - Which RouterBoard
I am not an expert in Mikrotik, so I need some help.
I have a Router Os installed in a server and it’s working very well.
My problem is that I need a Routerboard that supports PIM Routing, but I do not know which one is recommended. I have a RB 750, but it does not support PIM.
I don’t need a very expensive one, because my application is very simple. Which RB do you recommend?
Thanks!
PIM Routing is supported on all Routerboards, You just need to install multicast package on your device.
You can find Multicast packages here, under “Extra packages”
http://www.mikrotik.com/download
Thank you very much. :slight_smile:
