The network in question here is 192.168.16.0/24, which should be on VLAN254, which is physically connected on ether8 on two MikroTik RB1200 routers, each running RouterOS 5.21.
ether8 on each MikroTik is a Gigabit Ethernet trunk cable connecting to a trunk port on a Dell switch. (Two Dell switches; both PowerConnect 28xx series).
Here is the Dell switch port configuration applied to each of those two port-switch combinations:
Frame type: Admit Tagged Only
Ingress Filtering: Enable
VLAN IDs configured (tagged): 101, 102, 254
So, these trunk ports, which have Ethernet cables connecting the MikroTik routers, will accept only tagged VLAN packets, and only on VLAN IDs 101, 102 and 254.
On MikroTik1:
[jlibove@SP-MikroTik1] /ip firewall nat> /ip addr print #n.b. I removed lines for disabled addresses
ADDRESS NETWORK INTERFACE
0 ;;; MikroTik1’s real IP address
192.168.1.3/21 192.168.0.0 ether5
3 ;;; Private subnet between the MikroTiks for fallback cross-routing
192.168.8.3/29 192.168.8.0 ether9
5 ;;; Internal LAN VRRP virtual router IP address shared by the two MikroTiks
192.168.1.1/32 192.168.1.1 vrrp1
9 ;;; ONO fiber static IP address for when we are not using VRRP
84.124.127.10/29 84.124.127.8 ether4
10 ;;; Orange ISP static IP address for when we are not using VRRP
88.87.214.210/30 88.87.214.208 ether6
12 ;;; Wi-Fi Management VLAN router
192.168.17.2/24 192.168.17.0 ether1
13 192.168.17.1/32 192.168.17.1 vrrp4
14 ;;; Wi-Fi Internal Users VLAN virtual router IP address
192.168.12.1/32 192.168.12.1 vrrp5
15 ;;; Wi-Fi Internal Users VLAN physical IP address for this MikroTik router
192.168.12.3/22 192.168.12.0 ether2
17 ;;; Wi-Fi Guest VLAN physical interface of this Mikrotik
192.168.16.2/24 192.168.16.0 VLAN254 >
[jlibove@SP-MikroTik1] /ip firewall nat> /ip route print #n.b. I removed lines for disabled routes
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
3 A S ;;; One of two shared Default Internet connections, ONO (no mark considerations)
0.0.0.0/0 84.124.127.9 1
4 S ;;; Fallback cross-route to the other MikroTik
0.0.0.0/0 192.168.8.2 110
7 ADC 84.124.127.8/29 84.124.127.10 ether4 0
8 ADC 88.87.214.208/30 88.87.214.210 ether6 0
9 ADC 192.168.0.0/21 192.168.1.3 ether5 0
10 ADC 192.168.1.1/32 192.168.1.1 vrrp1 0
11 ADC 192.168.8.0/29 192.168.8.3 ether9 0
12 ADC 192.168.12.0/22 192.168.12.3 ether2 0
13 ADC 192.168.12.1/32 192.168.12.1 vrrp5 0
14 ADC 192.168.16.0/24 192.168.16.2 VLAN254 0
15 ADC 192.168.17.0/24 192.168.17.2 ether1 0
16 ADC 192.168.17.1/32 192.168.17.1 vrrp4 0
On MikroTik2:
[jlibove@SP-MikroTik2] /ip firewall nat> /ip addr print #n.b. I removed lines for disabled addresses
0 ;;; MikroTik2’s real IP address
192.168.1.2/21 192.168.0.0 ether5
192.168.8.2/29 192.168.8.0 ether9
12 ;;; Wi-Fi Management VLAN router NEED TO SET UP VRRP OR SIMILAR FOR THIS. DISABLED ON THIS PARTICULAR MIKROTIK FOR NOW.
192.168.17.1/32 192.168.17.0 vrrp4
13 192.168.17.3/24 192.168.17.0 ether1
192.168.12.2/22 192.168.12.0 ether2
192.168.16.3/24 192.168.16.0 VLAN254 >
[jlibove@SP-MikroTik2] /ip firewall nat> /ip route print #n.b. I removed lines for disabled routes
3 S ;;; One of two shared Default Internet connections, ONO (no mark considerations)
4 A S ;;; Fallback cross-route to the other MikroTik
0.0.0.0/0 192.168.8.3 110
7 ADC 192.168.0.0/21 192.168.1.2 ether5 0
8 DC 192.168.1.1/32 192.168.1.1 vrrp1 0
9 ADC 192.168.8.0/29 192.168.8.2 ether9 0
10 ADC 192.168.12.0/22 192.168.12.2 ether2 0
11 DC 192.168.12.1/32 192.168.12.1 vrrp5 0
12 ADC 192.168.16.0/24 192.168.16.3 VLAN254 0
13 ADC 192.168.17.0/24 192.168.17.3 ether1 0
14 DC 192.168.17.0/32 192.168.17.1 vrrp4 0
Now, on MikroTik1, I try to ping 192.168.16.2 and 192.168.16.3:
[jlibove@SP-MikroTik1] /ip route> /ping 192.168.16.3
HOST SIZE TTL TIME STATUS
192.168.16.3 timeout
sent=2 received=0 packet-loss=100%
[jlibove@SP-MikroTik1] /ip route> /ping 192.168.16.3 interface=ether8
[jlibove@SP-MikroTik1] /ip route> /ping 192.168.16.3 interface=VLAN254
[jlibove@SP-MikroTik1] /ip route> /ping 192.168.16.2
192.168.16.2 56 64 5ms
192.168.16.2 56 64 0ms
sent=2 received=2 packet-loss=0% min-rtt=0ms avg-rtt=2ms max-rtt=5ms
.. and the same on MikroTik2:
[jlibove@SP-MikroTik2] /ip firewall nat> /ping 192.168.16.2
192.168.16.2 timeout
[jlibove@SP-MikroTik2] /ip firewall nat> /ping 192.168.16.2 interface=ether8
[jlibove@SP-MikroTik2] /ip firewall nat> /ping 192.168.16.2 interface=VLAN254
[jlibove@SP-MikroTik2] /ip firewall nat> /ping 192.168.16.3
192.168.16.3 56 64 4ms
192.168.16.3 56 64 0ms
sent=2 received=2 packet-loss=0% min-rtt=0ms avg-rtt=2ms max-rtt=4ms
Why doesn’t ‘the other’ MikroTik reply across the VLAN trunk in each case?
(I have tested, by the way, that VLAN trunking between the two Dell PowerConnect switches works correctly; we have VLANs crossing them in production. For example, if I configure a port on one of the two Dell PowerConnect switches in Access mode for VLAN 254, and another port on the other Dell PowerConnect switch in Access mode for VLAN 254, and plug in normal PCs on those two ports, then they can see each other, with their packets being tagged for VLAN 254 on entering their respective switch, and the tagged packets successfully crossing a trunk between the two Dell switches, and then the packets being untagged and sent out the other PC’s port on its switch. So I assume that I have the whole port/ VLAN/ tagging/ mode thing right on the Dell switches. I am not at all so sure about my MikroTik configurations…).
Am I missing something in the MikroTik configuration for it to really be sending and expecting to receive only tagged packets over ether8?
Is there some additional step required for a MikroTik to respond to a PING coming in over a VLAN on a physical Ethernet port? I think that bridging is only needed if I want packets arriving on a VLAN to go untagged out a physical port on the MikroTik.
Thanks,
-Jay
