Here goes the complete configuration. I was recultant to send it all, because it is quite long, and I’m not sure if I could replace all sensitive information.
router 1:
# jan/16/2022 12:46:02 by RouterOS 6.48.5
# software id = R847-LG5N
# model = RBD52G-5HacD2HnD
# serial number = *************
/caps-man channel
add band=2ghz-onlyn extension-channel=XX frequency="" name=channels-2.4 \
secondary-frequency="" tx-power=-10
add band=5ghz-onlyac extension-channel=XXXX frequency="" name=channels-5 \
secondary-frequency="" skip-dfs-channels=yes tx-power=15
add band=2ghz-onlyn extension-channel=XX frequency=2412 name=c24-1 tx-power=\
-10
add band=2ghz-onlyn extension-channel=XX frequency=2437 name=c24-6 tx-power=\
-10
add band=2ghz-onlyn extension-channel=XX frequency=2462 name=c24-11 tx-power=\
-10
/caps-man datapath
add local-forwarding=yes name=datapath-blue vlan-id=10 vlan-mode=use-tag
add local-forwarding=yes name=datapath-green vlan-id=20 vlan-mode=use-tag
add local-forwarding=yes name=datapath-red vlan-id=30 vlan-mode=use-tag
add local-forwarding=yes name=datapath-cyan vlan-id=40 vlan-mode=use-tag
add local-forwarding=yes name=datapath-base vlan-id=99 vlan-mode=use-tag
add frame-types=admit-only-vlan-tagged ingress-filtering=yes name=BR1 \
vlan-filtering=yes
add name=ipsec protocol-mode=none
set [ find default-name=ether1 ] name=ether1-trunk
set [ find default-name=ether2 ] name=ether2-gray
set [ find default-name=ether3 ] name=ether3-gray
set [ find default-name=ether4 ] name=ether4-lte
set [ find default-name=ether5 ] name=ether5-wan
/interface wireless
# managed by CAPsMAN
# channel: 2437/20-Ce/gn(-13dBm), SSID: base, local forwarding
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode \
amsdu-limit=4096 band=2ghz-onlyn basic-rates-a/g=12Mbps basic-rates-b="" \
country=hungary disabled=no distance=indoors frequency=2437 mode=\
ap-bridge rate-set=configured ssid=lacinet_24 station-roaming=enabled \
supported-rates-a/g=12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps \
supported-rates-b="" tx-power-mode=all-rates-fixed wireless-protocol=\
802.11 wps-mode=disabled
# channel: 5300/20-eeCe/ac/DP(12dBm), SSID: base, local forwarding
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode \
amsdu-limit=4096 band=5ghz-onlyac basic-rates-a/g=12Mbps,36Mbps,48Mbps \
channel-width=20/40mhz-Ce country=hungary disabled=no distance=indoors \
mode=ap-bridge ssid=lacinet_5 station-roaming=enabled \
tx-power-mode=all-rates-fixed wireless-protocol=802.11 wps-mode=disabled
/interface vlan
add interface=BR1 name=BASE_VLAN vlan-id=99
add interface=BR1 name=BLUE_VLAN vlan-id=10
add interface=BR1 name=CYAN_VLAN vlan-id=40
add interface=BR1 name=GREEN_VLAN vlan-id=20
add interface=BR1 name=HALL_VLAN vlan-id=200
add interface=BR1 name=RED_VLAN vlan-id=30
/caps-man rates
add basic=12Mbps name=rates-2.4 supported=\
add basic=12Mbps name=rates-5 supported=\
/caps-man security
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm name=\
security-blue
security-green
security-cyan
security-red
security-base
/caps-man configuration
add channel=channels-5 country=hungary datapath=datapath-blue installation=\
any name=caps-blue-5 rates=rates-5 security=security-blue ssid=blue
add channel=channels-2.4 country=hungary datapath=datapath-blue installation=\
any name=caps-blue-2.4 rates=rates-2.4 security=security-blue ssid=blue
add channel=channels-2.4 country=hungary datapath=datapath-green \
installation=any name=caps-green-2.4 rates=rates-2.4 security=\
security-green ssid=green
add channel=channels-5 country=hungary datapath=datapath-green installation=\
any name=caps-green-5 rates=rates-5 security=security-green ssid=green
add channel=channels-5 country=hungary datapath=datapath-red installation=any \
name=caps-red-5 rates=rates-5 security=security-red ssid=red
add channel=channels-2.4 country=hungary datapath=datapath-red installation=\
any name=caps-red-2.4 rates=rates-2.4 security=security-red ssid=red
add channel=channels-2.4 country=hungary datapath=datapath-cyan installation=\
any name=caps-cyan-2.4 rates=rates-2.4 security=security-cyan ssid=cyan
add channel=channels-5 country=hungary datapath=datapath-cyan installation=\
any name=caps-cyan-5 rates=rates-5 security=security-cyan ssid=cyan
add channel=channels-2.4 country=hungary datapath=datapath-base hide-ssid=yes \
installation=any name=caps-base-2.4 rates=rates-2.4 security=\
security-base ssid=base
add channel=channels-5 country=hungary datapath=datapath-base hide-ssid=yes \
installation=any name=caps-base-5 rates=rates-5 security=security-base \
ssid=base
/caps-man interface
add channel=c24-11 configuration=caps-base-2.4 disabled=no l2mtu=2026 \
mac-address=48:8F:5A:A1:AB:30 master-interface=none name=orange.lacinet-1 \
radio-mac=48:8F:5A:A1:AB:30 radio-name=488F5AA1AB30
add configuration=caps-blue-2.4 disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:A1:AB:30 master-interface=orange.lacinet-1 name=\
orange.lacinet-1-1 radio-mac=00:00:00:00:00:00 radio-name=4A8F5AA1AB30
add configuration=caps-green-2.4 disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:A1:AB:31 master-interface=orange.lacinet-1 name=\
orange.lacinet-1-2 radio-mac=00:00:00:00:00:00 radio-name=4A8F5AA1AB31
add configuration=caps-red-2.4 disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:A1:AB:32 master-interface=orange.lacinet-1 name=\
orange.lacinet-1-3 radio-mac=00:00:00:00:00:00 radio-name=4A8F5AA1AB32
add configuration=caps-cyan-2.4 disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:A1:AB:33 master-interface=orange.lacinet-1 name=\
orange.lacinet-1-4 radio-mac=00:00:00:00:00:00 radio-name=4A8F5AA1AB33
add channel.extension-channel=XXXX channel.frequency=5200 comment=ch40 \
configuration=caps-base-5 disabled=no l2mtu=1600 mac-address=\
48:8F:5A:A1:AB:31 master-interface=none name=orange.lacinet-2 radio-mac=\
48:8F:5A:A1:AB:31 radio-name=488F5AA1AB31
add configuration=caps-blue-5 disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:A1:AB:34 master-interface=orange.lacinet-2 name=\
orange.lacinet-2-1 radio-mac=00:00:00:00:00:00 radio-name=4A8F5AA1AB34
add configuration=caps-green-5 disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:A1:AB:35 master-interface=orange.lacinet-2 name=\
orange.lacinet-2-2 radio-mac=00:00:00:00:00:00 radio-name=4A8F5AA1AB35
add configuration=caps-red-5 disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:A1:AB:36 master-interface=orange.lacinet-2 name=\
orange.lacinet-2-3 radio-mac=00:00:00:00:00:00 radio-name=4A8F5AA1AB36
add configuration=caps-cyan-5 disabled=no l2mtu=1600 mac-address=\
4A:8F:5A:A1:AB:37 master-interface=orange.lacinet-2 name=\
orange.lacinet-2-4 radio-mac=00:00:00:00:00:00 radio-name=4A8F5AA1AB37
add channel=c24-6 configuration=caps-base-2.4 disabled=no l2mtu=1600 \
mac-address=B8:69:F4:09:BE:FA master-interface=none name=router.lacinet-1 \
radio-mac=B8:69:F4:09:BE:FA radio-name=B869F409BEFA
BA:69:F4:09:BE:FA master-interface=router.lacinet-1 name=\
router.lacinet-1-1 radio-mac=00:00:00:00:00:00 radio-name=BA69F409BEFA
BA:69:F4:09:BE:FB master-interface=router.lacinet-1 name=\
router.lacinet-1-2 radio-mac=00:00:00:00:00:00 radio-name=BA69F409BEFB
BA:69:F4:09:BE:FC master-interface=router.lacinet-1 name=\
router.lacinet-1-3 radio-mac=00:00:00:00:00:00 radio-name=BA69F409BEFC
BA:69:F4:09:BE:FD master-interface=router.lacinet-1 name=\
router.lacinet-1-4 radio-mac=00:00:00:00:00:00 radio-name=BA69F409BEFD
add channel=channels-5 channel.extension-channel=XXXX channel.frequency=5300 \
comment=ch40 configuration=caps-base-5 disabled=no l2mtu=1600 \
mac-address=B8:69:F4:09:BE:FB master-interface=none name=router.lacinet-2 \
radio-mac=B8:69:F4:09:BE:FB radio-name=B869F409BEFB
BA:69:F4:09:BE:FE master-interface=router.lacinet-2 name=\
router.lacinet-2-1 radio-mac=00:00:00:00:00:00 radio-name=BA69F409BEFE
BA:69:F4:09:BE:FF master-interface=router.lacinet-2 name=\
router.lacinet-2-2 radio-mac=00:00:00:00:00:00 radio-name=BA69F409BEFF
BA:69:F4:09:BF:00 master-interface=router.lacinet-2 name=\
router.lacinet-2-3 radio-mac=00:00:00:00:00:00 radio-name=BA69F409BF00
BA:69:F4:09:BF:01 master-interface=router.lacinet-2 name=\
router.lacinet-2-4 radio-mac=00:00:00:00:00:00 radio-name=BA69F409BF01
add name=WAN
add name=VLAN
add name=BASE
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
/ip dhcp-server option
add code=119 name=domain-search-option value="'lacinet.'"
/ip ipsec policy group
add name=group-viszfuvar
add name=group-kavicsbanya
add name=group-office
add name=group-magzatom
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 name=\
profile_l2tp
add dh-group=modp2048,modp1536,modp1024 enc-algorithm=aes-256,aes-192,aes-128 \
hash-algorithm=sha256 name=profile-s2s-ros proposal-check=strict
/ip ipsec peer
add comment="IKE2 default" exchange-mode=ike2 name=peer_ike2 passive=yes \
profile=profile-s2s-ros send-initial-contact=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 comment=\
"For l2tp-server" enc-algorithms=aes-256-cbc pfs-group=modp2048
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc name=proposal-s2s-ros \
pfs-group=modp2048
add name=BLUE_POOL ranges=10.14.10.100-10.14.10.200
add name=GREEN_POOL ranges=10.14.20.100-10.14.20.200
add name=RED_POOL ranges=10.14.30.100-10.14.30.200
add name=BASE_POOL ranges=192.168.14.100-192.168.14.200
add name=CYAN_POOL ranges=10.14.40.100-10.14.40.200
add address-pool=BLUE_POOL disabled=no interface=BLUE_VLAN lease-script=\
onDhcpLease name=BLUE_DHCP
add address-pool=GREEN_POOL disabled=no interface=GREEN_VLAN name=GREEN_DHCP
add address-pool=RED_POOL disabled=no interface=RED_VLAN name=RED_DHCP
add address-pool=BASE_POOL disabled=no interface=BASE_VLAN name=BASE_DHCP
add address-pool=CYAN_POOL disabled=no interface=CYAN_VLAN name=CYAN_DHCP
/ppp profile
add dns-server=10.14.200.1,1.1.1.3 local-address=10.14.200.1 name=l2tp_vpn
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes upgrade-policy=\
suggest-same-version
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=BASE_VLAN
/caps-man provisioning
add action=create-enabled hw-supported-modes=ac master-configuration=\
caps-base-5 name-format=identity slave-configurations=\
caps-blue-5,caps-green-5,caps-red-5,caps-cyan-5
add action=create-enabled master-configuration=caps-base-2.4 name-format=\
caps-blue-2.4,caps-green-2.4,caps-red-2.4,caps-cyan-2.4
add bridge=BR1 frame-types=admit-only-vlan-tagged ingress-filtering=yes \
interface=ether1-trunk
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged \
ingress-filtering=yes interface=ether2-gray pvid=99
ingress-filtering=yes interface=ether3-gray pvid=99
set discover-interface-list=BASE
/interface bridge vlan
add bridge=BR1 comment=Base tagged=BR1,ether1-trunk untagged=\
ether2-gray,ether3-gray vlan-ids=99
add bridge=BR1 comment=Cyan/IOT tagged=BR1,ether1-trunk vlan-ids=40
add bridge=BR1 comment=Blue tagged=BR1,ether1-trunk vlan-ids=10
add bridge=BR1 comment=Green/Guest tagged=BR1,ether1-trunk vlan-ids=20
add bridge=BR1 comment=Red tagged=BR1,ether1-trunk vlan-ids=30
/interface l2tp-server server
set authentication=mschap2 default-profile=l2tp_vpn enabled=yes use-ipsec=\
required
add interface=ether5-wan list=WAN
add interface=BLUE_VLAN list=VLAN
add interface=GREEN_VLAN list=VLAN
add interface=RED_VLAN list=VLAN
add interface=BASE_VLAN list=BASE
add interface=CYAN_VLAN list=VLAN
add interface=ether4-lte list=WAN
/interface wireless cap
set bridge=BR1 certificate=request discovery-interfaces=BASE_VLAN enabled=yes \
interfaces=wlan1,wlan2
add address=192.168.14.254/24 interface=BASE_VLAN network=192.168.14.0
add address=10.14.10.1/24 interface=BLUE_VLAN network=10.14.10.0
add address=10.14.20.1/24 interface=GREEN_VLAN network=10.14.20.0
add address=10.14.30.1/24 interface=RED_VLAN network=10.14.30.0
add address=10.14.40.1/24 interface=CYAN_VLAN network=10.14.40.0
add address=10.14.200.1/24 interface=HALL_VLAN network=10.14.200.0
add address=10.14.100.2/24 interface=ether4-lte network=10.14.100.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=2m
/ip dhcp-client
add disabled=no interface=ether5-wan
/ip dhcp-server lease
add address=10.14.10.105 client-id=1:80:e8:2c:e:ef:d2 mac-address=\
80:E8:2C:0E:EF:D2 server=BLUE_DHCP
add address=10.14.10.10 client-id=1:ac:12:3:3c:c:c6 mac-address=\
AC:12:03:3C:0C:C6 server=BLUE_DHCP
add address=192.168.14.101 comment=brocade mac-address=00:27:F8:98:F7:60 \
server=BASE_DHCP
add address=192.168.14.100 client-id=1:4:d9:f5:f7:79:a7 mac-address=\
04:D9:F5:F7:79:A7 server=BASE_DHCP
add address=192.168.14.201 client-id=\
ff:e2:34:3f:3e:0:2:0:0:ab:11:81:6e:af:75:4d:19:27:61 mac-address=\
08:00:27:30:C8:89 server=BASE_DHCP
add address=192.168.14.202 client-id=\
ff:e2:34:3f:3e:0:2:0:0:ab:11:f9:f8:2a:df:10:8c:52:0 mac-address=\
08:00:27:CB:B4:BE server=BASE_DHCP
add address=192.168.14.203 client-id=\
ff:e2:34:3f:3e:0:2:0:0:ab:11:4:79:e:30:c2:fc:ea:75 mac-address=\
08:00:27:7B:36:DB server=BASE_DHCP
add address=192.168.14.205 client-id=\
ff:e2:34:3f:3e:0:2:0:0:ab:11:ea:d4:c5:c8:e3:a4:72:73 mac-address=\
08:00:27:48:6E:15 server=BASE_DHCP
add address=192.168.14.204 client-id=\
ff:e2:34:3f:3e:0:2:0:0:ab:11:de:60:b5:f7:9c:52:91:67 mac-address=\
08:00:27:C6:DA:2E server=BASE_DHCP
add address=10.14.10.0/24 dns-server=192.168.14.254 domain=lacinet. gateway=\
10.14.10.1
add address=10.14.20.0/24 dns-server=192.168.14.254 domain=pubnet. gateway=\
10.14.20.1
add address=10.14.30.0/24 dns-server=192.168.14.254 gateway=10.14.30.1
add address=10.14.40.0/24 dns-server=192.168.14.254 gateway=10.14.40.1
add address=192.168.14.0/24 dns-server=192.168.14.254 gateway=192.168.14.254
set allow-remote-requests=yes servers=1.1.1.2,1.0.0.2
/ip dns static
add address=192.168.14.254 name=router.lacinet
add address=192.168.14.253 name=poe-switch.lacinet
add address=192.168.14.252 name=orange.lacinet
add address=10.14.100.1 name=lte.lacinet
add forward-to=192.168.5.254 regexp=".*\\.visznet" type=FWD
add comment=visznet forward-to=192.168.5.254 regexp=\
".*\\.5\\.168\\.192.\\in-addr\\.arpa" type=FWD
add forward-to=192.168.18.254 regexp=".*\\.kavicsnet" type=FWD
add comment=kavicsbanya-base forward-to=192.168.18.254 regexp=\
".*\\.18\\.168\\.192.\\in-addr\\.arpa" type=FWD
add forward-to=192.168.13.254 regexp=".*\\.sznet" type=FWD
add comment=sznet-base forward-to=192.168.13.254 regexp=\
".*\\.13\\.168\\.192.\\in-addr\\.arpa" type=FWD
add forward-to=192.168.19.254 regexp=".*\\.magnet" type=FWD
add comment=magzatom-base forward-to=192.168.19.254 regexp=\
".*\\.19\\.168\\.192.\\in-addr\\.arpa" type=FWD
add comment=magzatom-vlan forward-to=192.168.19.254 regexp=\
".*\\.19\\.10.\\in-addr\\.arpa" type=FWD
add address=10.14.200.101 name=forgach.lacinet
add address=10.14.200.102 name=erika.lacinet
add address=10.14.200.103 name=tony-i7.lacinet
add address=10.14.200.1 name=hall.lacinet
add address=10.14.10.105 name=htpc.lacinet
add address=10.14.200.105 name=kardirex.lacinet
add address=10.14.200.106 name=szek.lacinet
add address=10.14.200.107 name=stonemining.lacinet
add address=10.14.200.108 name=edit.lacinet
add address=10.14.200.109 name=szucsnorbi.lacinet
add address=10.14.200.111 name=nyergesati.lacinet
add address=10.14.200.110 name=ghbackup.lacinet
add address=192.168.14.101 name=brocade.lacinet
add address=192.168.14.100 name=laci-ryzen9.lacinet
add address=10.14.200.113 comment=bukkszenterzsebet name=backup.lacinet
add address=192.168.14.201 name=coc01.lacinet
add address=192.168.14.202 name=coc02.lacinet
add address=192.168.14.203 name=coc03.lacinet
add address=192.168.14.204 name=coc04.lacinet
add address=192.168.14.205 name=coc05.lacinet
add address=192.168.14.104 name=gw.lacinet
add address=10.14.200.112 name=silyegabi.lacinet
add address=10.14.10.105 comment=#DHCP name=htpc.lacinet. ttl=10m
add address=10.14.10.124 comment=#DHCP name=M2101K6G.lacinet. ttl=10m
"Allow IKEv2 500, IKEv2 NAT-T 4500, L2TP 1701" port=500,4500,1701 \
protocol=udp
"Allow IPSEC/ESP (also used below L2TP/UDP)" protocol=ipsec-esp
add action=accept chain=input comment="Accept established,related,untracked" \
add action=drop chain=input comment="Drop invalid" connection-state=invalid
add action=accept chain=input comment="Accept ICMP" protocol=icmp
add action=accept chain=input comment="Input from BASE mgmt" \
in-interface-list=BASE
add action=jump chain=input comment="SSH input, with brute force protection" \
dst-port=22 in-interface=!RED_VLAN jump-target=input_ssh protocol=tcp
add action=jump chain=input comment="Input from VLAN" in-interface-list=VLAN \
jump-target=input_from_vlan
add action=jump chain=input jump-target=input_from_l2tp src-address=\
10.14.200.0/24
add action=accept chain=input comment="Required by CAPsMAN" dst-address-type=\
local src-address-type=local
add action=drop chain=input comment=Drop
add action=drop chain=input_ssh comment="drop ssh brute forcers" \
src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist \
address-list-timeout=1w3d chain=input_ssh connection-state=new \
src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 \
address-list-timeout=1m chain=input_ssh connection-state=new \
src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 \
src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 \
add action=accept chain=input_from_vlan comment="Local DNS UDP" dst-port=53 \
protocol=udp
add action=accept chain=input_from_vlan comment="Local DNS TCP" dst-port=53 \
protocol=tcp
add action=accept chain=input_from_vlan comment="Local NTP UDP" dst-port=123 \
protocol=udp
add action=accept chain=input_from_vlan comment="DHCP 67 UDP" dst-port=67 \
protocol=udp
add action=accept chain=input_from_vlan comment="DHCP 68 UDP" dst-port=68 \
protocol=udp
add action=reject chain=input_from_vlan in-interface=RED_VLAN reject-with=\
icmp-admin-prohibited
add action=drop chain=input_from_vlan comment=Drop
"Accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="Drop invalid" connection-state=invalid
add action=jump chain=forward jump-target=from_htpc src-address=10.14.10.105
add action=reject chain=from_htpc comment=\
"Reject HTPC->Any when we are on LTE" out-interface=ether4-lte \
reject-with=icmp-admin-prohibited
add action=accept chain=from_htpc comment="kalihomok slave/vnc htpc->forgach" \
dst-address=10.14.200.101 dst-port=5432,5900 protocol=tcp
add action=accept chain=from_htpc comment=\
"kavicsbanya slave/vnc htpc->borika-pc" dst-address=192.168.18.199 \
add action=accept chain=from_htpc comment="htpc->visznet full access" \
dst-address=192.168.5.0/24
"stonemining slave/vnc htpc->stonemining" dst-address=10.14.200.107 \
add action=accept chain=forward comment="l2tp laci-vivobook -> any" \
src-address=10.14.200.104
add action=reject chain=forward comment="Commonly hacked ports" \
connection-state=new dst-port=21,23,25,110,135,1433 protocol=tcp \
add action=reject chain=forward comment="Reject RED->Internet" \
connection-state=new in-interface=RED_VLAN out-interface-list=WAN \
add action=accept chain=forward comment="Allow VLAN->Internet" \
connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=accept chain=forward comment="Allow BASE->Internet" \
connection-state=new in-interface-list=BASE out-interface-list=WAN
add action=accept chain=forward comment="BASE->VLAN src-nated" \
connection-state=new in-interface-list=BASE out-interface-list=VLAN
"BASE->10.14.x.x includes BASE->L2TP and BASE->LTE" connection-state=new \
dst-address=10.14.0.0/16 in-interface-list=BASE
add action=reject chain=forward comment=\
"After accept rules - net-unreach when ipsec is down" out-interface=ipsec \
reject-with=icmp-network-unreachable
add action=drop chain=forward comment="Drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new disabled=yes \
in-interface-list=WAN
add action=drop chain=forward comment=Drop
add action=accept chain=input_ssh
add action=accept chain=input_from_l2tp comment="DNS from l2tp client (tcp)" \
dst-port=53 protocol=tcp
add action=accept chain=input_from_l2tp comment="DNS from l2tp client (udp)" \
dst-port=53 protocol=udp
add action=accept chain=input_from_l2tp comment="NTP from l2tp client (udp)" \
dst-port=123 protocol=udp
add action=reject chain=input_from_l2tp reject-with=icmp-admin-prohibited
add action=return chain=from_htpc
/ip firewall mangle
add action=change-mss chain=forward comment=\
"IKE2: Clamp TCP MSS for in,ipsec" ipsec-policy=in,ipsec new-mss=1360 \
passthrough=yes protocol=tcp tcp-flags=syn tcp-mss=!0-1360
"IKE2: Clamp TCP MSS for out,ipsec" ipsec-policy=out,ipsec new-mss=1360 \
add action=passthrough chain=prerouting comment=x dst-address=192.168.14.0/24 \
protocol=icmp src-address=192.168.19.254
add action=jump chain=srcnat comment="Src-Nat l2tp laci-vivobook-> any" \
jump-target=srcnat_laci_l2tp src-address=10.14.200.104
add action=src-nat chain=srcnat comment="Src-Nat BASE->BLUE" out-interface=\
BLUE_VLAN src-address=192.168.14.0/24 to-addresses=10.14.10.1
add action=src-nat chain=srcnat comment="Src-Nat BASE->RED" out-interface=\
RED_VLAN src-address=192.168.14.0/24 to-addresses=10.14.30.1
add action=src-nat chain=srcnat comment="Src-Nat BASE->CYAN" out-interface=\
CYAN_VLAN src-address=192.168.14.0/24 to-addresses=10.14.40.1
add action=src-nat chain=srcnat comment="Src-Nat BASE->HALL" dst-address=\
10.14.200.0/24 src-address=192.168.14.0/24 to-addresses=10.14.200.1
add action=src-nat chain=srcnat comment="Src-Nat BASE->LTE-mgmt" \
out-interface=ether4-lte src-address=192.168.14.0/24 to-addresses=\
10.14.100.2
add action=src-nat chain=srcnat_laci_l2tp comment=\
"Src-Nat l2tp laci-vivbook->ipsec" out-interface=ipsec to-addresses=\
192.168.14.254
"Src-Nat l2tp laci-vivobook->l2tp (inter-l2tp)" dst-address=\
10.14.200.0/24 to-addresses=10.14.200.1
add action=dst-nat chain=dstnat comment=\
"postgres kali-homok slave backup.router1.test.com->lacinet->forgach-vpn" \
dst-port=54321 in-interface=ether5-wan protocol=tcp src-address=\
1.2.3.4 to-addresses=10.14.10.105 to-ports=5432
add action=src-nat chain=srcnat comment=\
dst-port=5432,5900 protocol=tcp src-address=10.14.10.105 to-addresses=\
10.14.200.1
add action=src-nat chain=srcnat comment="kalihomok slave/vnc htpc->forgach" \
dst-address=10.14.200.101 dst-port=5432,5900 protocol=tcp src-address=\
10.14.10.105 to-addresses=10.14.200.1
add action=src-nat chain=srcnat comment="kavicsbanya slave htpc->borika-pc" \
dst-address=192.168.18.199 dst-port=5432,5900 protocol=tcp src-address=\
10.14.10.105 to-addresses=192.168.14.254
add action=src-nat chain=srcnat comment="Src-Nat htpc->visznet all" \
dst-address=192.168.5.0/24 src-address=10.14.10.105 to-addresses=\
192.168.14.254
add action=masquerade chain=srcnat comment="Default masquerade" ipsec-policy=\
out,none out-interface-list=WAN
"Src-Nat l2tp laci-vivobook->blue" dst-address=10.14.10.0/24 \
/ip ipsec identity
add auth-method=digital-signature certificate=laci.router1.test.com comment=\
office.partner1.test.com generate-policy=port-strict match-by=certificate \
my-id=fqdn:laci.router1.test.com peer=peer_ike2 policy-template-group=\
group-viszfuvar remote-certificate=office.partner1.test.com remote-id=\
fqdn:office.partner1.test.com
office.router1.test.com generate-policy=port-strict match-by=certificate my-id=\
fqdn:laci.router1.test.com peer=peer_ike2 policy-template-group=group-office \
remote-certificate=office.router1.test.com remote-id=fqdn:office.router1.test.com
kavicsbanya.partner2.test.com generate-policy=port-strict match-by=certificate \
group-kavicsbanya remote-certificate=kavicsbanya.partner2.test.com remote-id=\
fqdn:kavicsbanya.partner2.test.com
office.partner3.magnet.com generate-policy=port-strict match-by=certificate \
group-magzatom remote-certificate=office.partner3.magnet.com remote-id=\
fqdn:office.partner3.magnet.com
/ip ipsec policy
set 0 comment="For l2tp-server"
add comment=office.partner1.test.com dst-address=192.168.5.0/24 group=\
group-viszfuvar proposal=proposal-s2s-ros src-address=192.168.14.0/24 \
template=yes
add comment=office.router1.test.com dst-address=192.168.13.0/24 group=group-office \
proposal=proposal-s2s-ros src-address=192.168.14.0/24 template=yes
add comment=kavicsbanya.router1.test.com dst-address=192.168.18.0/24 group=\
group-kavicsbanya proposal=proposal-s2s-ros src-address=192.168.14.0/24 \
template=yes
add comment=office.partner3.magnet.com dst-address=192.168.19.0/24 group=\
group-magzatom proposal=proposal-s2s-ros src-address=192.168.14.0/24 \
template=yes
add comment=office.partner3.magnet.com-vlan dst-address=10.19.0.0/16 group=\
template=yes
add comment="EKKE Telekom Mobil/LTE" disabled=yes distance=2 gateway=\
10.14.100.1
add comment="Prevent package leak RFC1918 class A" distance=1 dst-address=\
10.0.0.0/8 type=unreachable
add comment="VPN to magnet-vlan" distance=1 dst-address=10.19.0.0/16 gateway=\
ipsec pref-src=192.168.14.254
add comment="Prevent package leak RFC1918 class B" distance=1 dst-address=\
172.16.0.0/12 type=unreachable
add comment="Prevent package leak RFC1918 class C" distance=1 dst-address=\
192.168.0.0/16 type=unreachable
add comment="VPN to visznet" distance=1 dst-address=192.168.5.0/24 gateway=\
add comment="VPN to sznet" distance=1 dst-address=192.168.13.0/24 gateway=\
add comment="VPN to kavicsnet" distance=1 dst-address=192.168.18.0/24 \
gateway=ipsec pref-src=192.168.14.254
add comment="VPN to magnet-base" distance=1 dst-address=192.168.19.0/24 \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set winbox address=192.168.14.0/24
set api-ssl disabled=yes
/ip ssh
set host-key-size=4096 strong-crypto=yes
/ppp secret
add name=forgach profile=l2tp_vpn remote-address=10.14.200.101 service=l2tp
add name=erika profile=l2tp_vpn remote-address=10.14.200.102 service=l2tp
add name=tony_i7 profile=l2tp_vpn remote-address=10.14.200.103 service=l2tp
add name=laci-vivobook profile=l2tp_vpn remote-address=10.14.200.104 service=\
l2tp
add name=kardirex profile=l2tp_vpn remote-address=10.14.200.105 service=l2tp
add name=szek profile=l2tp_vpn remote-address=10.14.200.106 service=l2tp
add name=stonemining profile=l2tp_vpn remote-address=10.14.200.107 service=\
l2tp
add name=edit profile=l2tp_vpn remote-address=10.14.200.108 service=l2tp
add name=szucsnorbi profile=l2tp_vpn remote-address=10.14.200.109 service=\
l2tp
add name=ghbackup profile=l2tp_vpn remote-address=10.14.200.110
add name=nyergesati profile=l2tp_vpn remote-address=10.14.200.111
add name=silyegabi profile=l2tp_vpn remote-address=10.14.200.112
add name=backupmesshu profile=l2tp_vpn remote-address=10.14.200.113
/routing filter
add chain=dynamic-in set-check-gateway=ping
/system clock
set time-zone-name=Europe/Budapest
/system identity
set name=router.lacinet
/system logging
add topics=wireless
/system ntp client
set enabled=yes server-dns-names=0.hu.pool.ntp.org,1.hu.pool.ntp.org
/system package update
set channel=long-term
/system scheduler
add interval=1d name=e-mail-backup on-event=e-mail-backup policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=jan/01/1970 start-time=20:00:00
/system script
add dont-require-permissions=no name=onDhcpLease owner=gandalf policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n\
\n\
\n:local DHCPtag\
\n:set DHCPtag \"#DHCP\"\
\n\
\n:if ( [ :len \$leaseActIP ] <= 0 ) do={ :error \"empty lease address\" }\
\n\
\n:if ( \$leaseBound = 1 ) do=\\\
\n{\
\n :local ttl\
\n :local domain\
\n :local hostname\
\n :local fqdn\
\n :local leaseId\
\n :local comment\
\n\
\n /ip dhcp-server\
\n :set ttl [ get [ find name=\$leaseServerName ] lease-time ]\
\n network \
\n :set domain [ get [ find \$leaseActIP in address ] domain ]\
\n \
\n .. lease\
\n :set leaseId [ find address=\$leaseActIP ]\
\n\
\n# Check for multiple active leases for the same IP address. It's weird a\
nd it shouldn't be, but just in case.\
\n\
\n :if ( [ :len \$leaseId ] != 1) do=\\\
\n {\
\n :log info \"DHCP2DNS: not registering domain name for address \$lease\
ActIP because of multiple active leases for \$leaseActIP\"\
\n :error \"multiple active leases for \$leaseActIP\"\
\n } \
\n\
\n :set hostname [ get \$leaseId host-name ]\
\n :set comment [ get \$leaseId comment ]\
\n /\
\n\
\n :if ( [ :len \$hostname ] <= 0 ) do={ :set hostname \$comment }\
\n\
\n :if ( [ :len \$hostname ] <= 0 ) do=\\\
\n {\
\n :log error \"DHCP2DNS: not registering domain name for address \$lea\
seActIP because of empty lease host-name or comment\"\
\n :error \"empty lease host-name or comment\"\
\n }\
\n :if ( [ :len \$domain ] <= 0 ) do=\\\
\n {\
seActIP because of empty network domain name\"\
\n :error \"empty network domain name\"\
\n }\
\n\
\n :set fqdn \"\$hostname.\$domain\"\
\n \
\n /ip dns static\
\n :if ( [ :len [ find name=\$fqdn and address=\$leaseActIP and disabled=\
no ] ] = 0 ) do=\\\
\n {\
\n :log info \"DHCP2DNS: registering static domain name \$fqdn for addr\
ess \$leaseActIP with ttl \$ttl\"\
\n add address=\$leaseActIP name=\$fqdn ttl=\$ttl comment=\$DHCPtag dis\
abled=no\
\n } else=\\\
\n {\
\n :log error \"DHCP2DNS: not registering domain name \$fqdn for addres\
s \$leaseActIP because of existing active static DNS entry with this name \
or address\" \
\n }\
\n /\
\n} \\\
\nelse=\\\
\n{\
\n /ip dns static\
\n :local dnsDhcpId \
\n :set dnsDhcpId [ find address=\$leaseActIP and comment=\$DHCPtag ]\
\n\
\n :if ( [ :len \$dnsDhcpId ] > 0 ) do=\\\
\n {\
\n :log info \"DHCP2DNS: removing static domain name(s) for address \$l\
easeActIP\"\
\n remove \$dnsDhcpId\
\n }\
\n /\
\n}\
\n\
\n"
add dont-require-permissions=no name=e-mail-backup owner=gandalf policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/\
system backup save encryption=aes-sha256 name=\"email.backup\" password=\"\
********\";/tool e-mail send to=\"gandalf@router1.test.com\" subject=([/system id\
entity get name].\" (system=\".[/system package get system value-name=vers\
ion].\") backup\") file=email.backup;:log info \"Backup e-mail sent.\"; "
/tool bandwidth-server
set enabled=no
/tool e-mail
set address=mail.router1.test.com from=\
"MikroTik Hontalan router.lacinet <mikrotik@router1.test.com>" port=465 start-tls=\
tls-only user=mikrotik@router1.test.com
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=BASE
/tool mac-server ping
set enabled=no
/tool sniffer
set filter-ip-protocol=icmp
router 2:
# jan/16/2022 12:47:40 by RouterOS 6.48.5
# software id = BGJQ-V2CF
/caps-man channel
/caps-man datapath
vlan-filtering=yes
set [ find default-name=ether1 ] name=ether1-sw01
set [ find default-name=ether2 ] name=ether2-lte
set [ find default-name=ether3 ] name=ether3-blue
set [ find default-name=ether4 ] name=ether4-blue
/interface wireless
# channel: 2412/20-Ce/gn(-13dBm), SSID: magzatom_base, local forwarding
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
# channel: 5180/20-Ceee/ac/P(20dBm), SSID: magzatom_base, local forwarding
set [ find default-name=wlan2 ] disabled=no ssid=MikroTik
/interface vlan
/caps-man rates
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security-blue
add authentication-types=wpa2-psk encryption=aes-ccm name=security-green
add authentication-types=wpa2-psk encryption=aes-ccm name=security-red
add authentication-types=wpa2-psk encryption=aes-ccm name=security-base
any name=caps-blue-5 rates=rates-5 security=security-blue ssid=\
magzatom-privat
any name=caps-blue-2.4 rates=rates-2.4 security=security-blue ssid=\
magzatom-privat
security-green ssid=magzatom-vendeg
any name=caps-green-5 rates=rates-5 security=security-green ssid=\
magzatom-vendeg
security-base ssid=magzatom_base
ssid=magzatom_base
add channel=channels-2.4 country=hungary datapath=datapath-red hide-ssid=yes \
installation=any name=caps-red-2.4 rates=rates-2.4 security=security-red \
ssid=magzatom_red
add channel=channels-5 country=hungary datapath=datapath-red hide-ssid=yes \
installation=any name=caps-red-5 rates=rates-5 security=security-red \
ssid=magzatom_red
/caps-man interface
add configuration=caps-base-2.4 disabled=no l2mtu=1600 mac-address=\
08:55:31:E7:F3:6C master-interface=none name=r01.magnet-1 radio-mac=\
08:55:31:E7:F3:6C radio-name=085531E7F36C
0A:55:31:E7:F3:6C master-interface=r01.magnet-1 name=r01.magnet-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7F36C
0A:55:31:E7:F3:6D master-interface=r01.magnet-1 name=r01.magnet-1-2 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7F36D
0A:55:31:E7:F3:6E master-interface=r01.magnet-1 name=r01.magnet-1-3 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7F36E
add configuration=caps-base-5 disabled=no l2mtu=1600 mac-address=\
08:55:31:E7:F3:6D master-interface=none name=r01.magnet-2 radio-mac=\
08:55:31:E7:F3:6D radio-name=085531E7F36D
0A:55:31:E7:F3:6F master-interface=r01.magnet-2 name=r01.magnet-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7F36F
0A:55:31:E7:F3:70 master-interface=r01.magnet-2 name=r01.magnet-2-2 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7F370
0A:55:31:E7:F3:71 master-interface=r01.magnet-2 name=r01.magnet-2-3 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7F371
08:55:31:E7:E1:93 master-interface=none name=r02.magnet-1 radio-mac=\
08:55:31:E7:E1:93 radio-name=085531E7E193
0A:55:31:E7:E1:93 master-interface=r02.magnet-1 name=r02.magnet-1-1 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7E193
0A:55:31:E7:E1:94 master-interface=r02.magnet-1 name=r02.magnet-1-2 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7E194
0A:55:31:E7:E1:95 master-interface=r02.magnet-1 name=r02.magnet-1-3 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7E195
08:55:31:E7:E1:94 master-interface=none name=r02.magnet-2 radio-mac=\
08:55:31:E7:E1:94 radio-name=085531E7E194
0A:55:31:E7:E1:96 master-interface=r02.magnet-2 name=r02.magnet-2-1 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7E196
0A:55:31:E7:E1:97 master-interface=r02.magnet-2 name=r02.magnet-2-2 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7E197
0A:55:31:E7:E1:98 master-interface=r02.magnet-2 name=r02.magnet-2-3 \
radio-mac=00:00:00:00:00:00 radio-name=0A5531E7E198
add name=WAN
add name=VLAN
add name=BASE
add code=119 name=domain-search-option value="'magnet.'"
add name=group-lacinet
/ip ipsec profile
profile_l2tp
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 name=\
/ip ipsec peer
add address=92f20943ba88.sn.mynetname.net exchange-mode=ike2 name=\
laci.router1.test.com profile=profile-s2s-ros
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=4h name=\
proposal-s2s-ros pfs-group=modp2048
add name=BLUE_POOL ranges=10.19.10.100-10.19.10.200
add name=GREEN_POOL ranges=10.19.20.100-10.19.20.200
add name=RED_POOL ranges=10.19.30.100-10.19.30.200
add name=BASE_POOL ranges=192.168.19.100-192.168.19.200
/ppp profile
add dns-server=10.19.200.1,1.1.1.3 local-address=10.19.200.1 name=l2tp_vpn
/caps-man manager
identity slave-configurations=caps-blue-2.4,caps-green-2.4,caps-red-2.4
interface=ether1-sw01
ingress-filtering=yes interface=ether3-blue pvid=10
ingress-filtering=yes interface=ether4-blue pvid=10
add bridge=BR1 tagged=BR1,ether1-sw01 untagged=ether3-blue,ether4-blue \
vlan-ids=10
add bridge=BR1 tagged=BR1,ether1-sw01 vlan-ids=20
add bridge=BR1 tagged=BR1,ether1-sw01 vlan-ids=30
add bridge=BR1 tagged=BR1,ether1-sw01 vlan-ids=99
required
add interface=BASE_VLAN list=VLAN
add interface=ether2-lte list=WAN
add address=192.168.19.254/24 interface=BASE_VLAN network=192.168.19.0
add address=10.19.10.1/24 interface=BLUE_VLAN network=10.19.10.0
add address=10.19.20.1/24 interface=GREEN_VLAN network=10.19.20.0
add address=10.19.30.1/24 interface=RED_VLAN network=10.19.30.0
add address=10.19.200.1/24 interface=HALL_VLAN network=10.19.200.0
/ip cloud
/ip dhcp-client
add disabled=no interface=ether5-wan use-peer-dns=no
add default-route-distance=2 disabled=no interface=ether2-lte use-peer-dns=no
add address=10.19.10.198 client-id=1:74:fe:48:57:68:ae comment=\
"Nyugati Samsung Ultrahang, +smb share" mac-address=74:FE:48:57:68:AE \
server=BLUE_DHCP
add address=10.19.10.194 client-id=1:40:b0:76:5b:be:f8 comment=\
"Keleti vizsgalo desktop gep" mac-address=40:B0:76:5B:BE:F8 server=\
BLUE_DHCP
add address=10.19.30.10 client-id=1:ec:c8:9c:b9:9c:e5 comment="HkVision NVR" \
mac-address=EC:C8:9C:B9:9C:E5 server=RED_DHCP
add address=10.19.10.192 client-id=1:dc:a6:32:c8:1c:e6 comment=Babyscreen \
mac-address=DC:A6:32:C8:1C:E6 server=BLUE_DHCP
add address=10.19.10.190 client-id=1:0:17:c8:a6:90:55 comment=\
"KyoceraP6230CDN lezer" mac-address=00:17:C8:A6:90:55 server=BLUE_DHCP
add address=10.19.10.101 client-id=\
ff:b6:22:f:eb:0:2:0:0:ab:11:13:66:88:18:da:5e:fe:33 mac-address=\
98:90:96:CE:6F:92 server=BLUE_DHCP
add address=10.19.30.101 client-id=1:2c:a5:9c:fa:c4:5c mac-address=\
2C:A5:9C:FA:C4:5C server=RED_DHCP
add address=10.19.30.102 client-id=1:4c:f5:dc:5e:ff:37 mac-address=\
4C:F5:DC:5E:FF:37 server=RED_DHCP
add address=10.19.10.0/24 dns-server=192.168.19.254 domain=magnet. gateway=\
10.19.10.1
add address=10.19.20.0/24 dns-server=192.168.19.254 gateway=10.19.20.1
add address=10.19.30.0/24 dns-server=192.168.19.254 gateway=10.19.30.1
add address=192.168.19.0/24 dns-server=192.168.19.254 gateway=192.168.19.254
set allow-remote-requests=yes servers=1.1.1.3,1.0.0.3
/ip dns static
add address=192.168.19.254 name=r01.magnet
add address=192.168.19.253 name=r02.magnet
add address=192.168.19.252 name=r03.magnet
add address=192.168.19.244 name=sw01.magnet
add address=192.168.19.243 name=sw02.magnet
add address=192.168.19.242 name=sw03.magnet
add address=192.168.19.241 name=sw04.magnet
add address=10.19.30.10 name=nvr.magnet
add address=10.19.100.254 name=lte.magnet
add address=10.19.200.101 comment="L2TP Brigi Laptop" name=brigi.magnet
add address=10.19.200.103 comment="L2TP Brigi-oled laptop" name=\
brigi-oled.magnet
add address=10.19.200.102 comment="L2TP ViktorNAS" name=viktornas.magnet
add address=10.19.200.1 comment="L2TP hall" name=hall.magnet
add address=10.19.30.101 name=cam-folyoso.magnet
add address=10.19.30.102 name=cam-varo.magnet
add address=10.19.10.194 comment=#DHCP name=keleti-vizsgalo.magnet. ttl=10m
add address=10.19.10.106 comment=#DHCP name=DESKTOP-V210M8R.magnet. ttl=10m
add address=10.19.10.101 comment=#DHCP name=nas.magnet. ttl=10m
"Allow UDP 500,4500,1701 for IKE, IPSEC/ESP and L2TP" port=1701,500,4500 \
protocol=udp
add action=accept chain=input comment="Allow IPSEC/ESP" protocol=ipsec-esp
add action=accept chain=input comment="CAPsMAN and CAP" dst-address-type=\
dst-port=22 jump-target=input_ssh protocol=tcp
add action=jump chain=input comment="Input from L2TP client" jump-target=\
input_from_l2tp src-address=10.19.200.0/24
add action=accept chain=input comment="DNS from lacinet udp" dst-port=53 \
protocol=udp src-address=192.168.14.0/24
add action=accept chain=input comment="DNS from lacinet tcp" dst-port=53 \
protocol=tcp src-address=192.168.14.0/24
add action=accept chain=input_ssh comment="allow ssh from anywhere"
add action=drop chain=input_ssh comment=Drop
protocol=udp
protocol=tcp
protocol=udp
protocol=udp
protocol=udp
add action=accept chain=forward comment="Accept in ipsec policy" \
"Reply with network-unreachable when IPSEC tunnel is down" out-interface=\
ipsec reject-with=icmp-network-unreachable
add action=accept chain=forward comment="Allow BASE->VLAN" connection-state=\
add action=accept chain=forward comment="l2tp brigi-laptop->any" src-address=\
10.19.200.101
add action=accept chain=forward comment="l2tp brigi-oled->any" src-address=\
10.19.200.103
"l2tp viktornas.magnet->nas.magnet syncthing" dst-address=10.19.10.101 \
dst-port=22000,22 protocol=tcp src-address=10.19.200.102
"l2tp nas.magnet->viktornas.magnet syncthing" dst-address=10.19.200.102 \
dst-port=22000,22 protocol=tcp src-address=10.19.10.101
add action=accept chain=forward comment="ICMP between VLANs and HALL" \
disabled=yes dst-address=10.19.0.0/16 protocol=icmp src-address=\
10.19.0.0/16
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=src-nat chain=srcnat comment="scr-nat lacinet->RED" out-interface=\
RED_VLAN src-address=192.168.14.0/24 to-addresses=10.19.30.1
add action=src-nat chain=srcnat comment="Src-Nat base-lacinet->base-magnet" \
out-interface=BASE_VLAN src-address=192.168.14.0/24 to-addresses=\
192.168.19.254
add action=src-nat chain=srcnat comment="Src-Nat base-lacinet->hall-magnet" \
dst-address=10.19.200.0/24 src-address=192.168.14.0/24 to-addresses=\
10.19.200.1
add action=src-nat chain=srcnat comment="l2tp brigi-oled->magnet-blue" \
dst-address=10.19.10.0/24 src-address=10.19.200.103 to-addresses=\
10.19.10.1
add action=src-nat chain=srcnat comment="Src-Nat l2tp viktornas->nas" \
dst-address=10.19.10.101 src-address=10.19.200.102 to-addresses=\
10.19.200.1
/ip ipsec identity
add auth-method=digital-signature certificate=office.partner3.magnet.com my-id=\
fqdn:office.partner3.magnet.com peer=laci.router1.test.com policy-template-group=\
group-lacinet remote-id=fqdn:laci.router1.test.com
/ip ipsec policy
set 0 comment="For l2tp-server" dst-address=0.0.0.0/0 src-address=0.0.0.0/0
add dst-address=192.168.14.0/24 peer=laci.router1.test.com proposal=proposal-s2s-ros \
src-address=192.168.19.0/24 tunnel=yes
src-address=10.19.0.0/16 tunnel=yes
add comment="VPN to lacinet" distance=1 dst-address=192.168.14.0/24 gateway=\
ipsec pref-src=192.168.19.254
/ip service
set winbox address=192.168.19.0/24
/ip ssh
set strong-crypto=yes
/ppp secret
add name=brigi profile=l2tp_vpn remote-address=10.19.200.101 service=l2tp
add name=viktornas profile=l2tp_vpn remote-address=10.19.200.102 service=l2tp
add name=brigi-oled profile=l2tp_vpn remote-address=10.19.200.103 service=\
l2tp
/routing filter
/system clock
/system identity
set name=r01.magnet
/system logging
add topics=l2tp
add topics=ipsec
/system ntp client
/system scheduler
/system script
\n\
\n\
\n:local DHCPtag\
\n\
\n\
\n{\
\n :local ttl\
\n :local domain\
\n :local hostname\
\n :local fqdn\
\n :local leaseId\
\n :local comment\
\n\
\n /ip dhcp-server\
\n network \
\n \
\n .. lease\
\n\
\n\
\n {\
\n } \
\n\
\n /\
\n\
\n\
\n {\
\n }\
\n {\
\n }\
\n\
\n \
\n /ip dns static\
no ] ] = 0 ) do=\\\
\n {\
abled=no\
\n } else=\\\
\n {\
or address\" \
\n }\
\n /\
\n} \\\
\nelse=\\\
\n{\
\n /ip dns static\
\n\
\n {\
easeActIP\"\
\n }\
\n /\
\n}\
\n\
\n"
***********\";/tool e-mail send to=\"gandalf@router1.test.com\" subject=([/system id\
set enabled=no
/tool e-mail
set address=mail.router1.test.com from="Mikrotik r01.magnet <mikrotik@router1.test.com>" port=\
465 start-tls=tls-only user=mikrotik@router1.test.com
/tool mac-server
set enabled=no
/tool sniffer
set filter-ip-protocol=udp filter-port=dns
