Hello all,
I’ve following Network
WAN0 IP address X.X.X.X is connected with interent
LAN0 ip address 192.168.0.1 is used to connect with some ip cameras using ip block 192.168.0. 0/24
LAN0 ip address 192.168.1.1 is used as some windows machines ( using ip block 192.168.1.0/24) internet gateway.
LAN1 ip address 192.168.2.1 is used as some windows machines ( using ip block 192.168.2.0/24) internet gateway
I want from both network windows stations can connect with IP block 192.168.0.0/24 in LAN Speed. how can i ping ip 192.168.0.2 from these two network 192.168.1.2 and 192.168.2.2
regards
Should work automatically.
Eth1=WAN, IP: x.x.x.x
Eth2=LAN, IP: 192.168.0.1/24
Eth3=LAN, IP: 192.168.1.1/24
Eth4=LAN, IP: 192.168.2.1/24
From default config, you’d have to edit interface Eth3 and Eth4 and set master-port to none.
Then set the interface IPs via IP > Addresses
Then set DHCP Server stuff for each lan interface
If you go to IP > Route, you’ll notice routes have automatically been created for the LAN networks. Routes are how the Mikrotik decides to send packets.
thanks for ur reply
no its nt working by default
[abc@MikroTik] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
1 ADC 192.168.199.0/24 192.168.199.1 ether1 0
2 ADC 192.168.230.0/24 192.168.230.1 ether2 0
[abc@MikroTik] > /ip address print
ADDRESS NETWORK INTERFACE
1 ;;; IP Camera IP BLOCK
192.168.199.1/24 192.168.199.0 ether1
2 ;;; LAN 1 IP Block
192.168.230.1/24 192.168.230.0 ether2
Still ip 192.168.230.2/24 gateway 192.168.230.1 can not ping IP 192.168.199.2 connected with ether1
Settings look correct.
192.168.199.2 blocking PING requests?
Test by going to Tools > Ping, select Ether2, try pinging it. Should reply.
Try same ping again, but with no interface selected. This makes the Mikrtoik use routing logic. Should reply.
Next go to Tools > Torch, select “Protocol” then on the right side, Protocol = ICMP
Ping repeatedly from 230.2 to 199.2 (ping 192.168.199.2 -t)
In Torch, select Ether2 interface. Click Start. You should see pings being received by 230.2, destined to 199.2 Click Stop, select Ether1, click start. You should see the ping coming back from 230.2, destined to 199.2.
Also from 230.2, ping 199.1. Works?
no . 199.2 is not blocking ping request.
i can ping both network from router without selecting any interface
i can not ping ether1 network by selecting ether2 interface and vice-versa
btw i’ve multiple ip configuration in both interface . is it the cause of problem ??
