Helloo
How to commission the dude ping som device From other device .
But J wont to ping was not from the dude serwer but from device .
Sory for my English ![]()
Helloo
You may only ping (or perform other actions) from another device if that device is a Dude Agent.
To be a Dude Agent, a device would need to be running Windows with Dude installed, or be a capable RouterOS device with the optional Dude package installed. Once the device is ready, you can create the Agent in your original Dude Server and request that certain actions be performed from the server directly, or from any of your configured remote Agents.
Wanned
How do I specify to the agent what to do? Can another part of a network be scanned by a remote agent and then it shows up on my local map?
I specified a remote agnet to discover devices but does it keep moniroting them or do you have to set it up for that agent to keep monitoring it?
Dolf
Ok. I think I answered my own question. I see I can specify in each item in dude who its agent is.
Is that right?
Dolf
