I’ve just started using Dude- and noticed that the history on all of the devices seems to be wrong. I start ping running from server to device and it’s 4-5ms, but the History in Dude shows 40-50 on graph.
Did I miss something somewhere?
You must have changed something somewhere as I don’t get that. If I run a ping it is 30-40mS, if I look at history for that same device, it is in the same range. (tested with Dude 3.5 on ROS4.6)
