Ping is timeout !
Hi every body;)
I hope you to be fine.
I have two RouterBOARD LHG 5nD with last update of mipsbe-6.46.2.
I made a point to point ( P2P ) connection between them, the one is master and the second is slave.
So, excuse me to ask you about:
When I do a ping to an address the result always is " Timeout " ;((
Really, I don’t know why?
I hope to help me to resolve that problem.
Thanks a lot.
Note: Fullbackup files of master & slave devices are attached below.
master fullbackup.rsc (2.71 KB)
slave fullbackup.rsc (2.49 KB)
Regards.
Feras Temimi
Actually, I’m curious about this too.
Try to ping another point with source command of ping module.
Thank you so much terminal205 for your interested.
Really! I hope this issue will be permanently resolved :wink:
Regards
Feras Temimi
Thank you so much Anumrak for your reply.
Yes, I have already used the method that you mentioned and tried repeatedly.
And, when I do a ping to an address like ( 8.8.8.8 ) or another seen,
the result always is " Timeout " !!?
So, can you help me to solve that problem?
Regards
Feras Temimi
add the route 0.0.0.0/0 via the gateway IP of the main router and try ping 8.8.8.8
Thank you so much flynno for your reply.
Yes, I have already tried all the available solutions according to my knowledge,
including the ones mentioned by you as well.
And, when I do a ping to an ip address like ( 8.8.8.8 ) or a domain name like ( mikrotik.com ) or another seen,
the result always is " Timeout " on my Mikrotik devices only not my computers ;(
i.e. the ping process is successfully running on my computers :wink:
So, I hope you to help me to resolve this issue permanently :wink:
Regards
Feras Temimi
Why do you have this
add action=masquerade chain=srcnat out-interface=bridge1
On a PtP Link? and on both ends too? where did you get this from?
WHY??
Thank you so much Znevna for your reply.
In fact, I found it as one of the solutions on some sites.
Now, I deleted it as I understood from your words :wink:
But the problem is still here ;(
Really! I hope you to help me to resolve this issue permanently :wink:
So, tell me what I do ?
Regards
Feras Temimi
