Which interfaces are the IPs assigned to?
Are both routers connected to the same L2 domain with the corresponding interfaces?
Ideally, you post a compact export of both routers.
-Chris
If your routers are directly connected, then why default route IP’s the same? They must be in the same subnet and default route IP of router 2 must be IP of router 1. Typically.
