Ping larger than 63 bytes not passing thru MikroTik AP
Bridged WDS network. Suddenly most of it stopped working properly. Only 63 or smaler pings are passed thru. 64 and larger are not passing any interface.
2.9.8-2.9.27 same, PC and RB. Downgrading, upgrading etc
I had similiar problem,
check out this two parameters:
default-ap-tx-limit=0
default-client-tx-limit=0
they should look like this.
Another parameters, in addition to this:
preamble-mode=long
disconnect-timeout=15s
this applies to atheros-based APs.
Regards,
Stoned.
Friends
Yes, couse your point still queue on that’s subnet full traffics
I thing this link make solved problem solution to make investigation point, you can pinging from that’s traffics without unlarge packet reply message [icmp-protocol].
Try to understand this manual link queue and mangle: http://www.mikrotik.com/docs/ros/2.9/ip/mangle.content#6.37.3
Thanks,
Regards
BalimoreDOTcom
:open_mouth:
:wink:
nice pinging… and nice dreams
regards,
WongGoendoel/BalimoreDOTcom
