ping latency high
Dear All,
I have a client that report to me about the high latency ping to my ISP DNS or http://www.yahoo.com if all of the client computer access to internet.
How to resolve this problem?
effendi
:open_mouth:
Are you using Queues?
Is the client maxing out his bandwidth? Because that’s the way queues work. Once client hits his maximum bandwidth, his latency will increase.
Dear znuff,
Yes I am using queues, PCQ type and the client bandwidth in maximum.
It’s the normal condidtion while using PCQ??
Yes, that’s how queues work. Under any system. When you reach maximum bandwidth, that’s the only way something is going to slow you down.
Packets will be slowed down and queued. That’s how latency appears :wink:
CMIIW,
as i know, you can assign a specific queue for ICMP or ping packet, so it wont get stuck at the same queue.
try it if you like.
hai,
yes, easy way will set it to traffic priority. :wink:
regards
Hasbullah.com
you can make a specific mangle/queue for icmp,
so when client use all quota,
icmp traffic still work fine.
