About a month or two ago I had to reinstall the windows beta since I had a VM issue. I tried to restore what I had but ended up having a hybrid since I had to recreate objects. The VM is running on W10 instead of W7. (and it was running W10 prior to the rebuild)
In any event a lot of my devices return the error “Local Problem” for Ping yet I can ping said devices from the VM or anywhere.
So what is this error and how can we fix it? a majority of my map is red or orange and it shouldn’t be.
This is user forum and by “you” you are referring to other users. I would like to see dude windows server continued, but I will probably move to CHR or x86 when the v.6 dude server will be at least as reliable as the 4b3 is now and there will not be windows server available.
Make sure to lower UAC and make sure the dude is running as administrator. When installing the dude make sure you are using an administrator account since it is probably setup to run as a service. There is an old thread somewhere about this problem although not win10. This could be a new problem.
