ping over 1500 bytes
Do you plan to make MT RouterOS can ping clients with more than 1500 bytes of data??? for example if I try to ping a client with packet of size of 65000 bytes I get “packet too large and cannot be fragmented”… but if I ping the router from client computer it works fine :shock: :shock: :shock: Did I made something wrong?
it is not possible to ping with size greater than the MTU
That did not directly answer his question, however icmp echo’s -may- be fragmented but icmp response message should not be generated when triggered by an icmp response message.
