I have 2 locations linked together using PPTP using 2 MK 750 routers. The problem that i saw is that i can ping the clients that are on location A from the remote location B, but not vice-versa. Instead, from location A i can ping only local interfaces of MK750 situated on remote location B (192.168.20.1). What am i missing? Please help.
My config is:
Location A:
local interface: 192.168.10.0/24
Location B:
local interface: 192.168.20.0/24
Tunnel: 192.168.100.1 on location A and 192.168.100.2 on remote location B
A compact export of both ends can help.
Location A; location B
Both end on 6.7
Enable bridge firewall on end B
Remove duplicate route in both A and B
On end B set use default profile on ppptp and not default-encryption
Try, please.
by 6.7 you mean to downgrade to 6.7?
Exactly. Too much problem on 6.8+
I use for test 1 RB750 and one 750GL, in export B ether1 is 1Gbit…
I can help you tomorrow, now must go to my home. Here are 19:48 ![]()
